Page 9 of 14 FirstFirst 1234567891011121314 LastLast
Results 81 to 90 of 140
Thread: Destinator 3 Frontend v1.1
  1. #81
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    What text is supposed to appear in the centre?
  2. #82
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    its when u press the q/s or car/walk button
  3. #83
    Oct 2003
    Madrid
    Quote Originally Posted by CdRsKuLL
    Yeah, I see it now. I just had a look at NM's updated front end.
  4. #84
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    TMC TMC TMC Yes... FANTASTIC... is it working ?
    Do you still have to limit your maps to 50 Mb ?
    Well done indeed..... and for those that have not been following the development ( Like me ) is there a simple 'this is how you install it ?'.
    Fantasic, might save me some money here... thinking about the next car now and v3 and I was looking at geting a real sat nav system and using a capture card to view via the system instead of been software based... if this is as good as it look I may have to change my mind...
    Well done.
    Terran
  5. #85
    May 2004
    Copenhagen
    To people from Skandinavia:
    Made a OSK and SKIN edit to support the letters ÆØÅ for version 1.0, will make a version for 1.1 soon.
    Http://www.skumlern.dk/S2forum/Skin.ini
    http://www.skumlern.dk/S2forum/OSK_OFF.jpg
    /Jonas R.
  6. #86
    Constant Bitrate weekendowel's Avatar
    Jan 2004
    Stockholm, Sweden
    I really love this!!!
    Can you make it pause WMP? And I will love it even more, so we can use it with Frodoplayer?
  7. #87
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    nearly finished the update to my skin, but I have come across 2 problems.. unsure if ninja can help..
    The first problem is the menu box wont quite center, and is dependent on the size of the screen, its taking the point from the bottom left corner of the pic and to make it work it would need to take it from the middle.
    The other problem it that because i'm using a white background, the text that appears in the center line doesnt show..
    If nothing can be done then I will change me skin to try and get it working right
    cheers
    CdR
    Ahh crap! I knew I forgot something...
    Leave it as it is mate, but add a line under Global called NotifyFontColor. I'm making some small changes in the next day or so and I'll add this to my list.
  8. #88
    Aug 2003
    Warrington, UK
    Quote Originally Posted by michel027
    NINJA,
    I've downloaded your new frond end. But don't see the TMC option.
    I have a GPS with TMC so i could test it for you. Please send the front end to test.
    What I've read in the manual (..ops ) that if you use destinator 3.1 PRO the TMC function is standing in the GPS settings window. There you can enable it. I have an installation of destinator 3.1 , when i search the files i see a exe file with TMC in the name. But I can't run it under a win32 api.
    In the SDK there is an function enabletmc haven't tried it out yet.
    I've also found the destinator c_client c++ source . Anybody interested in this see emule it was named "destinator sdk 3A"
    NINJA you're doing a good job... well done !!
    thanks.
    TMC is enabled by default (to make sure you can find it in the Settings.ini file in the Frontend folder).
    I have no idea if it works or not...hopefully somone can test for me
  9. #89
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Stupid question... What else does one need to use this program? Your frontend and what??
    Destinator SDK?? Just Destinator maps??
    Thanks!
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
  10. #90
    Aug 2003
    Warrington, UK
    Quote Originally Posted by tbird2340
    Thanks!
    The SDK is included with the package, you just need maps
  1. Headunit (Linux/Windows CarPC frontend) + initial screenshots
    By NoPistonPC in forum Other Cool Front Ends
    Last Post: 08-24-2007, 03:57 PM
  2. MediaCar, Ninja Monkey frontend and D3SDK
    By Skraggy_uk in forum Software & Software Development
    Last Post: 10-12-2004, 04:29 PM
  3. frontend
    By 00CericaRuss in forum Software & Software Development
    Last Post: 11-25-2003, 12:53 AM
  4. Docking WinAmp Visualizations in your frontend
    By qjones in forum Software & Software Development
    Last Post: 12-28-2002, 07:05 PM
  5. controlling mpg123 with a frontend
    By samael in forum Software & Software Development
    Last Post: 05-07-2001, 11:31 PM
