Page 1 of 14 1234567891011 ... LastLast
Results 1 to 10 of 140
Thread: Destinator 3 Frontend v1.1
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Exclamation Destinator 3 Frontend v1.1
    Edit: Links are back up! Those of you who downloaded it earlier need to get it again
    Hello!
    A lot of bug fixes and a few new features bring us to version 1.1 of my frontend
    Code:
    Version History
    [v1.1]
    *New Features*
    -InfoBar
    	An optional toolbar can appear at the top of the destinator window
    	containing the following information
    	- Current Location (Street/Road Name, City, Zip/Postal Code)
    	- Estimated Time of Arrival (Including Total distance of route)
    	- Estimated Time Remaining (Including total distance remaining)
    	- Winamp Controls (Next, Prev and Pause - Example skin is included)
    -Winsock Control
    	You can now create custom applications (Sample app included) to
    	connect to the frontend and control it yourself. Information
    	(such as Long, Lat, upcoming Maneuvers) can also be retrieved.
    	See the Developers sub directory for more information.
    -Route Generation Function
    	It's now possible to switch between Quickest and Shortest route
    	from a button on the menu bar. (Example skin is included)
    -Keyboard Shortcuts
    	Most (if not all) functions can be accessed via a customisable
    	Key combination
    -Updated Zoombar
    	The updated zoombar by weekendowel has been included in this version.
    	This makes it easier to use on a smaller screen. The previous zoom
    	buttons have been removed from the default skin (However the functions
    	are still available for skinning)
    -Updated Voices
    	A new voice pack (Thanks, CdRsKuLL) has been included as well as
    	the default
    -Size and Position
    	It's now possible to have the frontend remember the last size and
    	position of the window. You can either set these as permenant values
    	to use every time, or have the frontend save the current values
    	every time you close.
    -TMC Traffic Alerts
    	It's now possible to enable the TMC alert system within destinator. At
    	the time of writing this is unconfirmed to be fully functional.
    -Setup Screen / Skin Chooser
    	You can now configure the frontend easier using the setup screen. This
    	screen appears the first time you run the frontend (or after an upgrade)
    	or if you use the "/SETUP" command parameter.
    -New Skins
    	3 New skins have been included in the package.
    	* Classic [Wide OSK] by ŠuTcH
    	* Brushed Metal 1.0 by Ninja Monkey [OSK by ibutep]
    	* Metal by Ibutep
    *Changes / Fixes*
    -DestDLL
    	Maps of 50mb or more can now be opened (Thanks, Laidback)
    -Manuevers Screen Fix
    	Pressing Home would not clear the View Manuevers Screen. This has been
    	fixed
    -GPS Status Fix
    	Clicking GPS Status would open GPS Setup. It now opens the correct screen
    -OSK Now Optional
    	The On-Screen Keyboard can now be turned off by default. A new button
    	has been added to the toolbar to allow it to be activated (Example
    	skin is included)
    -Winamp Mute Fixed
    	Winamp now (optionally) mutes when a maneuver is approaching
    -Menus not working Fixed
    	A bug has been fixed where the menus would occasionally cease to function
    -OSK Not accepting extended characters fixed
    	The On Screen Keyboard would not transmit any characters above the 127
    	ASCII code range. This has now been fixed.
    -Height Offset
    	Some users were experiencing an incorrect height of the mapping window.
    	It's now possible to specify an offset value to compensate for such an
    	event. (Default is 35)
    +Various other undocumented bugs have been fixed
    [V1.0] - Initial Release
    *Features*
    -Skinnable Interface
    	A full frontend to control Destinator is included. An example Destinator
    	2 style skin has been included called "Default". All functions of the SDK
    	can be accessed from the menus.
    -Winamp Control
    	Although not included in the example skin, Basic winamp functions (Next,
    	Prev, Pause) can be assigned to buttons on the toolbar. Winamp can also
    	auto-mute when a maneuver is approaching.
    -On Screen Keyboard (OSK)
    	An auto-displaying OSK is included for entering addresses. This is also
    	skinnable.
    -Default Startup Mode
    	It is possible to specify Destinators default startup mode (2D, 3D and
    	Birds-Eye)
    -Updated DestDLL
    	A modified SDK library (Thanks, gnumike!) has been included that allows
    	maps of up to 50mb to be opened.
    -Map Cutter
    	Maps of 50mb or more can be cut down to size using this tool
    Those of you who already have 1.0 installed can upgrade using this:
    Destinator 3 Frontend 1.0 to 1.1 UPGRADE [4.5MB]
    The Full package can be downloaded here
    Destinator 3 Full Package 1.1 [8.2MB]
    Have Fun!
    Maximum Bitrate bertybassett's Avatar
    Sep 2003
    Gloucester (UK)
    thanx for the speedy update.
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    Damm, it looks promising. Downloading and testing in progress brb
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
    Newbie Grunge-Futtoch's Avatar
    Aug 2004
    Shropshire -Wales border
    Thanks for all your hard work. only wish I could help but all I can say is Thanks Man much appreaciated.
    Steve
    Variable Bitrate fly_dutchie's Avatar
    Feb 2004
    Amsterdam
    Quote Originally Posted by Ninja Monkey
    Hello!
    Have Fun!
    Hi Ninja Monkey,
    These links seem to point to the same file (the upgrade)
    Michael
    "It does not understand, if it does not ride."
    M10000, 512 Mb, 2,5" 40G, Slim DVD, Opus 90W, Xenarc 7", Leadtek 9532 GPS,
    RoadRunner, MapMonkey, Pioneer HU, Pioneer 4 ch 400W, Kappa 6.5, Basslink X 200W
    Exclamation
    Hi,
    Both links are for the upgrade - no full version.
    Aug 2003
    Warrington, UK
    Quote Originally Posted by haymaker
    Hi,
    Fixed! I'm a tired monkey!
    Constant Bitrate weekendowel's Avatar
    Jan 2004
    Stockholm, Sweden
    Thumbs up
    Fu** my BU-303 broke down and now this is released, well maybe it´s time to get a GPS with TMC support.
    Anyway this looks very, very good!!!!
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Could you enlighten me about the keyboard shortcuts? I have no clue were they are configurable. Also, can you make enter on the enter destination dialog box go to the next field?
    Low Bitrate TheKurbster's Avatar
    Sep 2003
    uninstalled all other versions and installed a fresh copy of ver 1.1 and for some reason i get error messages when after i type a route and navigate it then try to press like settings, or recaulate, it freezes and error comes up. been trying to see what is causing it but no luck. Note* it's not happening all the time though.
    anyone else having problems?
  1. Headunit (Linux/Windows CarPC frontend) + initial screenshots
    By NoPistonPC in forum Other Cool Front Ends
    Last Post: 08-24-2007, 03:57 PM
  2. MediaCar, Ninja Monkey frontend and D3SDK
    By Skraggy_uk in forum Software & Software Development
    Last Post: 10-12-2004, 04:29 PM
  3. frontend
    By 00CericaRuss in forum Software & Software Development
    Last Post: 11-25-2003, 12:53 AM
  4. Docking WinAmp Visualizations in your frontend
    By qjones in forum Software & Software Development
    Last Post: 12-28-2002, 07:05 PM
  5. controlling mpg123 with a frontend
    By samael in forum Software & Software Development
    Last Post: 05-07-2001, 11:31 PM
