Anyone?
Is it possible to manually include speed cameras and more POIs???
i.e. For Greek map!!!
Well you can add your own POI's as favorites (and have them show up on the map / alert you when you're close) if that's what you meanOriginally Posted by DjBac
Destinator 3 For PC! - http://www.map-monkey.co.uk/
I would like to add them in the POIs list... Is this possible??
What about cameras? Can I add them as favorites (including speed alert)??
you greeks dont need speed alert.. ur all nuts on the roads..
i been tring to find a way to put in heap of address into the bin file at once(i think) there all saved into. i asked once but it seemed to complex.
That's not for all the GREEKS!!!!Originally Posted by djmickyg
Sometimes you really need speed alert!!!
Yeah you tell me....Originally Posted by DjBac
btw we need speed alert to prevent engine meltdown....![]()
Hhhmm... That's a reason too!!!!!!!!!!!!Originally Posted by Seth
So, to the point.. Besides Favorites, can we edit POIs?
i.e. Add more gas stations etc..
Sorry to dtrag this OT, is speed cameras currently supported? How does one add a speed camera?
Is the new version going to include an easy button for adding a camera?
I have no idea how to go about ading cameras, but I hope it is easy enough to be able to do while driving...
As of 1.1.2 speed cameras are supported by adding them to your favorites and setting an alert. It's a bit fiddly to get working because you have to convert the database into the right format.Originally Posted by RoyN
1.1.3 has it's own speed camera detection built in. As well as automatically adding them to a favorites folder (so that they show on the map) you will get alerted (vebally and visually) when you are at a specified distance from the camera.
You can also choose to disable the verbal alert if you aren't actually speeding.
The cameras need to be stored in a CSV in the following format
Longitude,Latitude,Name,Speed
Adding new cameras is as easy as pressing 2 buttons ("Add Camera" and then the speed limit of the road)
