Results 21 to 30 of 36
Thread: Font Display Problem
  1. #21
    Variable Bitrate Frigor's Avatar
    Aug 2004
    Faenza, Italy
    Genius!
    BMW E36 Project [ ========= ]
    Hardware:
    Lilliput 7" Touchscreen - Epia M-10000 - HQCT 1.0 FM Radio - 2.5" 80Gb - USB GPS
    Software:
    FrodoPlayer 1.10 & MapMonkey with FriBruMet Skins by Frigor.
  2. #22
    Newbie unique's Avatar
    Oct 2004
    ATHENS-GREECE
    Man you are fantastic!!!!Thanx!!!!!!
  3. #23
    Apr 2005
    Israel
    Ageor,
    Thanks for the clean solution for this dirty problem.
    Spent days on solving (trying) this solution and it took me two minutes to follow your instruction and bam...
    BTW, I changed to hebrew code 177.
    Bye and thanks again.
    Zohar
  4. #24
    Apr 2005
    Israel
    Hebrew Fonts for D3
    BTW,
    If some one is looking for Hebrew, merge the attached file.
    Zohar
    (all rights to Ageor )
    Attached Files Attached Files
  5. #25
    Sep 2005
    Quote Originally Posted by ageor
    It seems Map Monkey (or is it Destinator?) doesn't care about Unicode character sets. The solution I implemented ...
    This is absolutely G - R - E - A - T - ! Thanks ageor.
    BUT - unfortunately there is a but -. It does not seem to work in the Avoid Roads -> Toll Roads -> Items menu.
    Any suggestions are welcome
  6. #26
    Apr 2005
    More font substitutes
    Quote Originally Posted by tempuser
    Thanks for the post (and all your kind words, everybody).
    It seems the lists use a different font than in the map (Tahoma), maybe Arial.
    It is always a good idea to set Control Panel | Regional and Language Options | Advanced | Select a language to match the language version of the non-Unicode programs you want to use: to your language (Greek, in this case) when you install Windows XP, but it's never too late. If you change it, you will need to reboot.
    If the above setting dows not work, merge the attached .reg file (exported from my PC). It is expanded to include more windows fonts, including Arial, Courier, Times New Roman and Tahoma (it normally works for any font you want; just add more entries using the same syntax). See the instructions in my previous post.
    Hope this helps; it works for me
  7. #27
    Sep 2005
    Unfortunately, this does not work on my Win2K box. In fact, there's no : Select a language to match the language version of the non-Unicode programs you want to use: in my Win2K. Never mind. I can exclude the tolls I don't like by selecting one and showing it on the map. Again, thanks for the brilliant patch.
  8. #28
    Apr 2005
    You are right, this is only available in WinXP.
    Did you try the .reg file?
  9. #29
    Sep 2005
    Yeah, I did. But it's kind of weird, since this is the only items menu that does not display in 161 codepage. I wonder what is the font they used.
  10. #30
    Apr 2005
    Could it be a skin matter?
  1. Replies: 7
    Last Post: 08-19-2005, 11:11 AM
  2. C# problem with HD44780 and DLPortIO
    By vasquez in forum LCD/Display
    Last Post: 05-29-2004, 05:49 PM
  3. Display brightness
    By ozoffi in forum LCD/Display
    Last Post: 05-14-2004, 05:12 PM
  4. Display problem in ME
    By cjones in forum ME Archive
    Last Post: 03-11-2003, 10:01 AM
  5. display, projected to the windshield
    By leon_id in forum LCD/Display
    Last Post: 02-23-2003, 03:32 AM
