What OS is on your laptops, never heard this one beforeOriginally Posted by clemen
Also, please don't post any more problems / bugs in this thread.
This is the fail report windows writes.
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Are questions ok for here? anyways, I finally got Sirf mode, which seems to have helped get better usage of GPS support here in sao paulo... locks are more reliabel apparently, with the ton of buildings in the area...
Anyways, advanced gps is just for nmea? any technical reason for that or is it just that sirf isnt ready yet? what are the differences? can i use speed cams in sirf? what are the other advantages of advanced mode?
It's just for NMEA I'm afraid.Originally Posted by RoyN
Advanced Mode will enable you to do the following:
Detect speed cameras
Overlay your current speed on the map
Display the number of satellites on the infobar
The rest is really for developers (the full nmea string can be queried, along with speed cameras, current heading etc.)
damn..... but nmea is slower than sirf right? will it ever be possible to support sirf? I dont see why it couldnt if all the information, speed, heading, etc is still available when using sirf.... can you share the limitation with us curious folk? I guess i might have to go back to nmea then!
Because I had to write code to parse the nmea data and retrieve all the information manually. SiRF is a completely different protocol and it'll take some time and a lot more coding before it's supported.Originally Posted by RoyN
Installed it in my home PC with no problems. Currently changing fonts![]()
Will test in the car tommorow (see it in action)
Good work NM
Cheers m8
I´m trying to use the project1 example.
When I try to connect I get a winsock error 10061.
Can you help me solve this please.
Heliodoro
Works great for me, love the new MPH displayed on the map.
肚子笑痛了
S60 Install
You need to allow applications to connect to the frontend, I've now set this to be disabled by default.Originally Posted by heliodoro
Open up C:\DestinatorApps\Frontend_PREV\Settings.ini
Find the line that reads
[Connection]
//Allow custom apps to connect to the frontend?
Enabled=No
and change it to
Enabled=Yes
Note that there are loads of new commands that aren't yet documented in the dev manual yet. I'll update it when I make an official release
