Page 10 of 11 FirstFirst 1234567891011 LastLast
Results 91 to 100 of 104
Thread: 1.1.3 BETA - Bug Reports
  1. #91
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Mauri: you might need to register the file... Start->Run->"regsvr32 c:\path\to\gtxp.dll" (no "")
  2. #92
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Quote Originally Posted by mauri
    Everything thanks for the collaboration.
    You are right, first a box of error but a second is visualized after XP " it covers" this box with one messageerror of his (what I have write9) and prevents me from seeing that principal that write so D3 Frontend.
    I am sure however' that the problem depends on the fact that the messages visualized in the Info bar are not visualized in the superior pixels to disposition of D3, but under, in the area reserved to C-Client.exe.
    True, happens Only if I use in Advance Mode, otherwise and' all ok.
    OK also the .dll write its in folder Fronted__Prev.
    Thanks.
    Mauri
    Yes but I'm guessing that you've just copied the DestinatorApps folder from your PC to the CarPC rather than installing it, so the DLL hasn't been registered with the system.
    Try running Register.BAT in C:\DestinatorApps
    Even if you think that it's already registered, just try it
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  3. #93
    Aug 2003
    Warrington, UK
    Quote Originally Posted by Laidback
    I've got lots of issues, hopefully you'll pull your finger out and fix them??
    You can count on my telepathic monkey brain to do anything!
  4. #94
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by Ninja Monkey
    Unfortunately no, I have made the new installation no copied the folder by the PC home to CarPc.
    However thanks, I will retry as you say (even if I already had done) then I make to know the results.
    Thanks Ninja.
    Mauri
  5. #95
    Aug 2003
    Warrington, UK
    Thanks Ninja.
    Mauri
    Just to help me work this out, how far does the frontend get before you recieve the error. Does the initial blue window even appear? Do you get the string "Loading Settings" at the top?
  6. #96
    FLAC mauri's Avatar
    Jan 2004
    Ok, after 2 hours of tests I succeed in making to work D3 1.1.3.
    The messages in the info cafe is visualized ok.
    I have discovered that and' a bug of communication between D3 and the setting of autodetect of the GPS.
    And precisely in the settings of the Bauds installments of the GPS in " Settings.ini."
    If I leave " AutoDetect" the usual error message writes me, if instead set to 4800 works, however' to I begin another ( D3 ) error writes me this:
    Error Details:
    Number: 6
    Description: Overflow (D3Request|ConnectGPS|1|4800|NMEA)
    Source: p_Command
    Version: 1.1.300
    HelpContext: 1000006
    HelpFile:
    LastDllError: 0
    If the click on OK and D3 works ok (tomorrow I make the tests in the street with the car).
    I have noticed however' that bugs there are other:
    If click on the button of the speed cam, when click on example 70, error:
    Error Details:
    Number: 6
    Description: Overflow (D3Request|AddSpeedCamera|-1|-1|70|-1 |)
    Source: p_Command
    Version: 1.1.300
    HelpFile:
    LastDllError: 0
    Other Bug:
    If you go with the buttons on " Favorites " the keyboard it doesn't work anymore.
    Embedded to thick Mediacard jams the correct operation of D3, especially when you go to setting the run to define with the button " Navigate" that you have added.
    I attach you my file Settings.ini to make to see you how I owe set to make to work D3.
    Thanks so many Ninja if you want to give us a view
    [Global]
    MuteWinampOnSpeak=Yes
    MuteVolume=0
    MuteTime=3
    OSKByDefault=Yes
    HeightOffset=35
    EnableTMC=No
    PauseFrodoOnSpeak=No
    FrodoPauseTime=3
    MuteLineOnSpeak=Yes
    LineToMute=0
    MuteLineTime=2
    MediaApp=0
    [Connection]
    //Allow custom apps to connect to the frontend?
    Enabled=No
    ListenPort=9913
    [Advanced GPS]
    //NMEA Receivers only
    UseAdvanced=Yes
    COMPort=1
    COMBaud=4800
    Protocol=NMEA
    //Speed Camera Detection
    SC_Enabled=Yes
    SC_Warning1=600
    SC_Warning2=100
    SC_AlertIfNotSpeeding=Yes
    SC_ShowOnMap=Yes
    SC_SpeedFormatInDB=KPH
    SC_DB=Italy
    [Startup]
    ViewMode=3D
    InfoBar=Yes
    ReconnectGPS=No
    D3Toolbar=No
    [Skin]
    //Name of Skin to use
    Skin=Mauri D3_2
    [SizeAndPos]
    SaveOnClose=No
    RestoreOnOpen=Yes
    XYWH=0|0|800|600
    WindowState=0
    // 0=Normal, 1=Minimised, 2=Maximized, 3=Fullscreen
    Mauri
  7. #97
    Nov 2004
    1/ I'm impressed by the developpement made by Ninja Monkey
    Thank you Ninja for your good work
    2/ I experiment the same problem Mauri have!
    When I uncheck advance GPS mode D3 works fine but no camera alert no speed display...
    When I check advance GPS mode with 4800 I see Error Details:
    Number: 6
    Source: p_Command
    Version: 1.1.300
    HelpFile:
    LastDllError: 0
    D3 works but the speed display stay at 0
    When I select autodetect I have this message
    Destinator3
    Run-time Error " 400 "
    for already displayed;cant show modally
    When I press OK, D3 frontend close.
    I'have tried all Ninja Monkey Suggested
    My configuration M10000 XP SP1 tft lilliput 7" GPS Haicom 204e
    Variable Bitrate LanoX's Avatar
    Aug 2004
    Sydney
    Quote Originally Posted by damdam1044
    Number: 6
    Source: p_Command
    Version: 1.1.300
    HelpFile:
    LastDllError: 0
    Destinator3
    2/ that is a bug far as i know i mentioned this before and he said he will look in to it ..
    also in some other posts he said to put baud rate on autoconfig as there is something wrong .... hmm i had simmilar problem but just play with the auto config myn end up working but not sure 100 what i done .,,..
    [|||||-----] 95% complete
  9. #99
    Nov 2004
    Hi
    When autodetect is selected I have this message error when D3 lauch:
    Destinator3
    for already displayed;cant show modally.
    I close this message but D3 close himself
    So for me autodetect doesn't work.
    I try autodetect without gps pluged (HI 204E serial mnea) And there is no error 400 displayed.
    Is it coming from GPS mouse?
    Mauri what is your GPS ?
    FLAC mauri's Avatar
    Jan 2004
    Hi
    Destinator3
    My GPS its the same , Haicom serial, but the problem its no the GPS but one bug in the sw, serial or USB is and' the same thing, what serves and' that its compatible NMEA 2.2 and in my case works to 4800 bauds, so' as yours, but also the most greater part of the receivers GPS with integrated active spar.
    The GPS USB work in the same mode whit the serial/mouse( mouse only for the power) .
    Whit the release 1.1.2 my GPS work perfectly!
    Ninja will resolve in the definitive release the problem, is sure.
    EDIT: also to me the same your identical thing happens, without " Autodetect " the satellites D3 " sees them" but to display speed doesn't work' and the number of the satellites in the info baraloft, not even the discourse speed cam obviously, over that the vocal message at times not read correctly.
    Mauri
  1. Bug Reports
    By frodobaggins in forum PV Bugs
    Last Post: 02-17-2005, 01:01 AM
  2. Bug Reports (FP 1.09 Take 2)
    By frodobaggins in forum FrodoPlayer
    Last Post: 11-01-2004, 07:59 AM
  3. Bug Reports 1.09
    Last Post: 10-22-2004, 11:24 PM
  4. Bug Reports
    Last Post: 10-16-2004, 01:25 AM
  5. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 05:32 PM
