Page 11 of 11 FirstFirst ... 234567891011
Results 101 to 104 of 104
Thread: 1.1.3 BETA - Bug Reports
  1. #101
    Nov 2004
    Thumbs up
    Quote Originally Posted by mauri
    My GPS its the same , Haicom serial, but the problem its no the GPS but one bug in the sw, serial or USB is and' the same thing, what serves and' that its compatible NMEA 2.2 and in my case works to 4800 bauds, so' as yours, but also the most greater part of the receivers GPS with integrated active spar.
    The GPS USB work in the same mode whit the serial/mouse( mouse only for the power) .
    Whit the release 1.1.2 my GPS work perfectly!
    Ninja will resolve in the definitive release the problem, is sure.
    EDIT: also to me the same your identical thing happens, without " Autodetect " the satellites D3 " sees them" but to display speed doesn't work' and the number of the satellites in the info baraloft, not even the discourse speed cam obviously, over that the vocal message at times not read correctly.
    Mauri
    Ok MAURI
    I'm sure Ninja will find the solution too.
    I'm testing D3 1.1.3 beta without advanced gps.
    Embeded in frodo I didn't see any other BUG. the ingregration with frodo is perfect and works great.
    Good Luck Ninja and thank you for your good work
  2. #102
    Variable Bitrate LanoX's Avatar
    Aug 2004
    Sydney
    Hey ninja sorry i didnt reply earlier i was busy with uni ..
    Here is the pic of the Red light that i drove past and i got no warnin of any kind waht so ever. Just to tell you i havent done any menual adding or anythign opnly what i done in advance GPS selected Australia and that was it..
    thank you very much
    [|||||-----] 95% complete
  3. #103
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Quote Originally Posted by LanoX
    thank you very much
    That isn't a camera from my database - if it was it would show as a large black/white speed cam, that's probably one that D3 already included in the australia map.
    If you could somehow export the camera POI's from D3 then you could include them, but until then you're SOL.
    Just for fun, if you add the camera manually - are you then alerted when you come close to it?
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  4. #104
    Aug 2004
    Sydney
    Quote Originally Posted by Ninja Monkey
    I havent tryed that yet ... hmmm dame...
  1. Bug Reports
    By frodobaggins in forum PV Bugs
    Last Post: 02-17-2005, 12:01 AM
  2. Bug Reports (FP 1.09 Take 2)
    By frodobaggins in forum FrodoPlayer
    Last Post: 11-01-2004, 06:59 AM
  3. Bug Reports 1.09
    Last Post: 10-22-2004, 10:24 PM
  4. Bug Reports
    Last Post: 10-16-2004, 12:25 AM
  5. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 04:32 PM
