Page 2 of 11 FirstFirst 1234567891011 LastLast
Results 11 to 20 of 104
Thread: 1.1.3 BETA - Bug Reports
  1. #11
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    No I'm running Destinator as a standalone and on settings.ini I have OSKByDefault=Yes
  2. #12
    Jun 2004
    Yamba NSW Australia
    Yes - Current Location and Satellite Icon and Red Zero are Showing.
    I was not speeding so therefore no voice warning - is it possible to add warning of Speed Cam anyway or does this occur with Logic Mode Off.
    Currently have logic mode on.
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Quote Originally Posted by Seth
    How about the Navigate button (bottom right)? Does it let you press that?
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  4. #14
    Aug 2003
    Warrington, UK
    Quote Originally Posted by AUSMARK
    Yep, if you always want a voice warning regardless of speed turn logic mode off - otherwise you'll just get the visual warning.
    Not sure what's happening with the current location - do you see a comma where the address should be?
  5. #15
    Jun 2004
    Athens Greece
    Seems to happen in the settings menu also. The HOME and MENU buttons are unusable and I must close the settings window "by-hand"
  6. #16
    Aug 2003
    Warrington, UK
    Seems to happen in the settings menu also. The HOME button is unusable and I must close the settings window "by-hand"
    Are you in fullscreen mode?
  7. #17
    Jun 2004
    Athens Greece
    Yes I think so...
  8. #18
    Aug 2003
    Warrington, UK
    Yes I think so...
    Can you try it without?
  9. #19
    Jun 2004
    Athens Greece
    Ninja you're right!! I re-run the Destinator config and selected "Maximized" instead of "Fullscreen" and the problem solved. But now I see my taskbar...
    Aug 2003
    Warrington, UK
    OK, well you've found a bug, because it should work
    Can you tell me what OS / Service pack?
  1. Bug Reports
    By frodobaggins in forum PV Bugs
    Last Post: 02-17-2005, 12:01 AM
  2. Bug Reports (FP 1.09 Take 2)
    By frodobaggins in forum FrodoPlayer
    Last Post: 11-01-2004, 06:59 AM
  3. Bug Reports 1.09
    Last Post: 10-22-2004, 10:24 PM
  4. Bug Reports
    Last Post: 10-16-2004, 12:25 AM
  5. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 04:32 PM
