Page 3 of 11 FirstFirst 1234567891011 LastLast
Results 21 to 30 of 104
Thread: 1.1.3 BETA - Bug Reports
  1. #21
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    I have Windows XP with Service Pack 2 and .NET Framework 1.1 SP1 and 2.0 Beta (dunno if that helps but...LET'S KILL THAT BUG )
  2. #22
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Can somebody else test the OSK in fullscreen mode?
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  3. #23
    Jun 2004
    Yamba NSW Australia
    Quote Originally Posted by Ninja Monkey
    Yep, if you always want a voice warning regardless of speed turn logic mode off - otherwise you'll just get the visual warning.
    Not sure what's happening with the current location - do you see a comma where the address should be?
    Sorry - I originally should have said Number of Satelites not showing but Current Location with Street and Town is showing.
  4. #24
    Aug 2003
    Warrington, UK
    Quote Originally Posted by AUSMARK
    Ahh, that's better
    I'll look into it!
  5. #25
    Jun 2004
    Yamba NSW Australia
    OSK in Full Screen Mode works fine for me.
  6. #26
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    re - skinning, it seems its pulling the bmp from the original place and not from the classic skin folder. I just tried changing the ones in the classic skin folder but nothing happend. Also the install is installing empty folders into the desapps folder. .not a biggie just thought I would point it out.. awesome job m8. I have one request.. would it be possible to turn off the speedtext shadow maybe ?
    keep it up fella.. its looking ace, should have a new skin for u next week sometime :-)
    Cheers
    CdR
  7. #27
    Jun 2004
    Athens Greece
    I'm sorry if I become a pain but I tested more and it seems that changing from "Fulscreen" to "Maximized" worked only the first time. After a program restart the same problem occurs...this is so odd and probably related with my PC...I'll investigate more and come back to you...
  8. #28
    Aug 2003
    Warrington, UK
    Quote Originally Posted by CdRsKuLL
    Cheers
    CdR
    In skin.ini change the Shadow color of the speed to -1
    With the Destinator Skin, you have to "Apply" the skin from the config menu, this will copy over all the relevent files
  9. #29
    Feb 2004
    Manchester
    ah kewl.. so it auto copies the needed files over :-) thanks m8 keep it up
  10. #30
    _wd
    _wd is offline
    Feb 2004
    Just did a test run with an install on my laptop (not connected to GPS now)
    - When advanced GPS mode is ON, i get an popup saying 'an error has occurred, the program needs to be closed. send/dont send error report'. But this could have something to do with not having a GPS device connected now.
    Extra bug info displayed:
    AppName: destinator3.exe AppVer: 1.1.0.300 ModName: kernel32.dll
    ModVer: 5.1.2600.2180 Offset: 0001eb33
    [Edit]
    OR, I get this message: (maybe it should check before accessing gps device)
    Error Details:
    Number: 6
    Description: Overflow (D3Request|ConnectGPS|1|4800|NMEA)
    Source: p_Command
    Version: 1.1.300
    HelpContext: 1000006
    HelpFile:
    LastDllError: 0
    [/Edit]
    - I tried to spot speed camera's on the map. There aren't any !? I've loaded map benelux and in settings.ini there is this line:
    SC_DB=Benelux
    I tried to change in to:
    SC_DB=Netherlands
    no luck either.
    When i look in the favorites, i can see the 'Fe_speedcams' category, but there are no items in it :?
    (There is also a category 'speed camera' which hold an item list starting with: 2,555,Ramat Ra-Sharon,Tel-Aviv Yafo,.... which seems to be test items)
    - As i restarted the program a few times i got a message saying 'destinator could already be running'. I checked and yes, it had 3 running instances (!)
  1. Bug Reports
    By frodobaggins in forum PV Bugs
    Last Post: 02-17-2005, 12:01 AM
  2. Bug Reports (FP 1.09 Take 2)
    By frodobaggins in forum FrodoPlayer
    Last Post: 11-01-2004, 06:59 AM
  3. Bug Reports 1.09
    Last Post: 10-22-2004, 10:24 PM
  4. Bug Reports
    Last Post: 10-16-2004, 12:25 AM
  5. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 04:32 PM
