Page 6 of 11 FirstFirst 1234567891011 LastLast
Results 51 to 60 of 104
Thread: 1.1.3 BETA - Bug Reports
  1. #51
    Variable Bitrate LanoX's Avatar
    Aug 2004
    Sydney
    Quote Originally Posted by Ninja Monkey
    Providing, in configuration, you have...
    Enabled Advanced GPS Mode
    Enabled Speed Camera Detection
    Chosen your country from the list of databases
    Then you should be ready
    ah its all good only in Frodo PLayer i cant embed it any more is that somethign i should ask Frodo or ??
    thanks man
    [|||||-----] 95% complete
  2. #52
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Quote Originally Posted by LanoX
    thanks man
    Just a guess, but that's probably because of the BETA nag screen.
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  3. #53
    Aug 2004
    Sydney
    Hey Ninja sorry man i got another problem when i went to my car and i changed it to enable advance GPS i get following error
    The error has occure in Destinator Frontend to ignore error and attempt to continue click ok
    Error Detail Numer: 6
    Description: Overflow (D3Request)ConnectGPS|4|4800|NMEA
    Source: Pcommand
    Versiom 1.1.3
    HelpContext: 1000006
    that is if i cahnge the ports and if i continue gps would work but speed meter in the corner on the map wont change and red light cams or speed cams wont work either..
    if i leav it on auto config gps wont work alltogether . it will say its not found
    thanks..
  4. #54
    Aug 2003
    Warrington, UK
    Source: Pcommand
    Versiom 1.1.3
    thanks..
    This has already been mentioned, in Advanced GPS - set the baud rate to AutoDetect
  5. #55
    Aug 2004
    Sydney
    Ah sorry man i just read it. i posted it and i though of i might go read first and yeah sorry for that ..... hmm also 1 thing you know the scroll up and down for zooming in the map is it suppose to resize its self if you set it the way you wont it..
    I think Ol33 mentioned this in previous version.
  6. #56
    Aug 2003
    Warrington, UK
    I'm not sure what you mean? The window resizes its self?
  7. #57
    Aug 2004
    Sydney
    Ah donít worry thanks again i fixed it it's my fault.... but its strange when i go to advance gps and select com 4 nad auto config for the rate everything works fine but when i go to settings GPS in D3 its saying that gps is on com 2 and rate 19200 something like that ?? why is that...
    Also if i have a speed camera/red-light it doesnít say which one it is it just says GAPO and how many meters.
    thanks
    Lano sorry for been pain man
  8. #58
    Oct 2004
    UK
    thanks
    Are you sure GAPO isn't GATSO.... The most popular UK speed cam
  9. #59
    Aug 2004
    Sydney
    Quote Originally Posted by johnwharrison
    Yeah you are right sorry as i said it was something like that huh
    Never heard of that expression that is all can you change it some how to say like eg. if its speed camera to say speed camera or if its redcam to a say rad cam as we do not call it or have GATSO here in aus...
    thanks
  10. #60
    Aug 2004
    Sydney
    Okay here it goes after long 3 hour drive today i had a good opportunity to test d3 and all the speed cam and red-light cam stuff ... This is the problems i came across
    1.Not all the cameras are detected sometime i would drive right past the camera and i would get no any notification even tho its set to warn you 600meters before but on the map you can see a camera picture ..
    2. When Logic mode is ticket i do not get any voice warning and also it does not detect all the cameras..
    3. When it does warn you voice says its speed camera but display warning says it red-light camera...
    4. Also if the speed camera is there and display shows a speed sign with no speed limit just a red circule with no number in it.
    that is so far that i can remember i am not sure if that is the bugs or m i doing something wrong tnx
    heaps
    Lano
  1. Bug Reports
    By frodobaggins in forum PV Bugs
    Last Post: 02-17-2005, 12:01 AM
  2. Bug Reports (FP 1.09 Take 2)
    By frodobaggins in forum FrodoPlayer
    Last Post: 11-01-2004, 06:59 AM
  3. Bug Reports 1.09
    Last Post: 10-22-2004, 10:24 PM
  4. Bug Reports
    Last Post: 10-16-2004, 12:25 AM
  5. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 04:32 PM
