Hi, trying to install.
Get this messange.
Operativ system Windows XP Pro SP2.
Any suggestions?
Regards and thanks
heliodoro
Post your bugs here
No feature requests
No off-topic discussion please
I'd like to be able to sort the bugs out ASAP, so keep it tidy![]()
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Get this messange.
Any suggestions?
Regards and thanks
heliodoro
I have got the TABCTL32.OCX , nsta335ng
regards
heliodoro
Just took it for a quick drive.
The Speedo and Speed Camera are great.
Bugs/Features not implemented? -
* Using with Frodo - D3 is not resuming after pause (does under previous version but not with this one) also mapping of play/next/last not working.
* Current Location and number of Satelites not showing in top left corner - have Advanced GPS Mode on and correct settings but not sure whether I need to play around with settings on GPS?
* Speed Camera - Icon does not appear on map until D3 restart and no voice warning of speed camera.
* Menu won't disappear by touching the map like previous version
That is all I found in the quick trip around the block but it is looking great.
Hope this helps.
AUSMARK
1. Thanks, I'll look into thatOriginally Posted by AUSMARK
2. Hmm, Do you see the little satellite icon? Is the header "Current Location" appearing?
3. Unfortunately the icon won't appear on the map until it's been refreshed - With the voice warning, do you have "Logic Mode" on? That means you won't get voice alerts unless you're actually speeding.
4. I'll sort it out![]()
Whit advanced mode the button of " add speeed camera" its not possible edit the latitude and longitude,ok to edit the speed limit, but not the rest of data.
If i click in the exsample 40 circle, error displayed type:
Error Details:
Number: 6
Description: Overflow (D3Request|AddSpeedCamera|-1|-1|50|-1|)
Source: p_Command
Version: 1.1.300
HelpContext: 1000006
HelpFile:
LastDllError: 0
For the rest it apperas for the first test all ok ( not in car use but test in the PC home!)
Good job Ninja![]()
Mauri
Thanks, I'll look into the error.Originally Posted by mauri
You can't edit the lon and lat information because it's designed to add a camera at your current location, that's the whole purpose of it.
Something is wrong with the OSK when I try to select an address in the "Destination" menu. When I'm there I cannot use the OSK (nothing happens when I press any of the keys)
*See pic*
When I close the upper (address) window the OSK works again...
*pic*
Are you running embedded? Do you have the OSK disabled by default?Originally Posted by Seth
