Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: SIRF anyone?
  1. #11
    Raw Wave
    Jun 2003
    I have never experienced SIRF as my garmin only support NMEAs. It always make me wonder why SIRF is better than the NMEA. Why would the GPS work more inferior when running on NMEA? its the same GPS, same chipset just different type of communications
    Wont it had to do with the s/w not handling the NMEA properly?
  2. #12
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Quote Originally Posted by Ricky327
    I think the main benefit of SiRF are the quicker updates. I believe it runs at 1Hz, so you get information from the sats around once per second - where as NMEA is around once every two seconds.
    It just means your position shown on the map will be more accurate, especially when you're travelling at high speed.
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  3. #13
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Hold on... so I can run my earthmate in SiRF mode for faster updates? Sweet
  1. Destinator 3 Frontend v1.1.3 BETA
    By Ninja Monkey in forum Map Monkey
    Last Post: 07-19-2005, 06:42 AM
  2. BU-303 and SIrf
    By matty_g in forum GPS
    Last Post: 11-15-2004, 01:18 PM
  3. iGuidance 2.0....LAME
    By antimatter in forum GPS
    Last Post: 08-03-2004, 12:41 AM
  4. anyone using SIRF mode?
    By PTCruiser in forum GPS
    Last Post: 03-04-2004, 11:30 AM
