Results 1 to 10 of 13
Thread: SIRF anyone?
    Sep 2003
    Vic. Australia
    SIRF anyone?
    I have a bu-303 gps receiver and was wondering if anyone had been able to get it working in sirf mode with destinator? I tried downloading sirfdemo and switching the mode on the gps receiver but destinator couldn't locate any satellites (at all). Anyone had any success or got any suggestions?
    Oct 2004
    UK
    are you sure the bu-303 supports sirf?
    it has to be a sirf chipset to do so.
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    BU-303 and SIrf
    NM's latest D3 front end - advanced gps mode - doesn't do sirf yet. But Destinator does.
    Nov 2004
    You'll have to download a program called sirfdemo.exe. It allows you to alter the configuration of the BU-303.
    Raw Wave
    Jun 2003
    Whats the advantage over NMEA?
    Sep 2003
    Vic. Australia
    Aparently NMEA has issues with destinator (read on a couple of sites), things such as dropouts, low signal strength, lagging etc.
    The bu-303 does use an sirf chipset and I was able to put it in sirf mode using sirfdemo but destinator couldn't interface with it properly, it detected that the gps existed but it couldn't locate any satellites at all.
    As far as advantages of SIRF goes, I'm not too sure as I haven't been able to get it working but to start with the baud rate the sirfdemo app was using was 34800 as appose to NMEA which uses 4800.
    Has anyone successfully used SIRF? or can anyone confirm if NinjaMonkeys version of destinator 3 supports it (its in the drop down list).
    Oct 2003
    Madrid
    Quote Originally Posted by grahamrb
    I've already told you! Destinator supports it, that's why it's in the list!! NM's front end runs on top of Destinator and has extra features that will only work with NMEA.
    Sydney, Australia
    i gave it a go and got a lock with nj's frontend
    it worked with 34800 as the baud rate, and refused to work with 4800
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    Quote Originally Posted by Ricky327
    You really have to try sirfdemo. It allows to adjust a number of settings on the gps mouse.
    D3 is usable to me only with sirf. in nmea, i just could't keep a stable lock long enought to be of any use.
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
    Jan 2004
    NYC
    does anyone know if the earthmate[yellow] supports this?
  1. Destinator 3 Frontend v1.1.3 BETA
    By Ninja Monkey in forum Map Monkey
    Last Post: 07-19-2005, 06:42 AM
  2. BU-303 and SIrf
    By matty_g in forum GPS
    Last Post: 11-15-2004, 01:18 PM
  3. iGuidance 2.0....LAME
    By antimatter in forum GPS
    Last Post: 08-03-2004, 12:41 AM
  4. anyone using SIRF mode?
    By PTCruiser in forum GPS
    Last Post: 03-04-2004, 11:30 AM
