Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 73
Thread: Alter the D3 positioning icon
  1. #21
    FLAC mauri's Avatar
    Jan 2004
    Mauri
  2. #22
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by mauri
    @Wizz
    Update the viper icon,size and new design.
    Tested in my auto , its ok whit D3.
    Download for test.
    Mauri
    Thank you, I will try it.
    1) What was the reason you increased the size ?
    2) The FOOT was just a thought because it was also on the button.
    3) I don't use "planning mode" much, but I also do not like the original
    "pushpin" icon. What are the special considerations when designing an icon
    for "planning mode" ?
    Wizz
    PS: I think I could do with a crash course in Italian !
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
  3. #23
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by wizz
    Wizz
    I have increased the size because in the daytime, with the Lilliput TS, the visibility in 2D days mode it was a little visible.For me its ok in this sizes.
    Also I don't use much to " planner mode" , but the original icon its horrible!
    It needs to consider that D3 in planner mode uses , as point of reference to view on the map ,the extremity of the original icon.
    Then every new icon to draw wanted to do has to keep in mind of this fact, you will see out otherwise always your icons the real roads of the map.
    PS: I also should take a course in English, excuse me if I don't make me understand!
    Mauri
  4. #24
    Nov 2004
    Leicestershire UK
    Mauri
    I have now tried Viper2 in my car and it is fine.
    I still don't quite understand the planner mode icon, but I agree with you it is poor compared to the other icons and it would be nice to change it.
    Does it have to be small and thin so that it does not cover up the roads on the map. Is that what you meant ?
    Wizz
  5. #25
    Nov 2004
    Leicestershire UK
    Yes, it has to be an icon that finishes thin with an indicative point as in the original version (you have seen how and done, it has an end point that the position marks on the map).
    Make a simple test in your car and replace the icon number 236 exsample to my red arrow.bmp
    You will acknowledge what I tell alone you, the arrow doesn't work ok on the map.
    EDIT: it doesn't care the greatness of the icon, but the final point of it.
    Mauri
    I understand now....
    OK, Thinking caps on..what is tall and thin and is more in keeping with the traffic theme.
    I'VE GOT IT !......how about a traffic light ?
    You have the thin post that it is attached to, which points to the exact spot on the map, and the light itself which would look much better than the "pushpin"
    What do you think ?
    Wizz
  6. #26
    FLAC mauri's Avatar
    Jan 2004
    Ok , i have draw the icon for planner mode.
    Its possible ONLY the circle icon adapt for this use,max 58 x 58 pixel, to centre in the map.Very difficult adapt this icon!
    Wizz, test the new icon and write to impression.
    Mauri
    Attached Files Attached Files
  7. #27
    FLAC mauri's Avatar
    Jan 2004
    Screen (icon in real size)
    Mauri
  8. #28
    Nov 2004
    Leicestershire UK
    So is that a NO to the traffic light because it would have to start at the centre and only be half the height of a normal icon ?
    Wizz
  9. #29
    FLAC mauri's Avatar
    Jan 2004
    To see to the center of the map the icon OWE to be as I have drawn me now, otherwise any icon comes out some center of the map,and see so very bad, out of the rout.
    My icon drawn it seems centered on the map.
    Even test also you if don't like it, we will use the best icons if work ok in future.
    Mauri
  10. #30
    Nov 2004
    Leicestershire UK
    OK, Will do...
    Will you try this one (TL1.zip)
    This icon is exactly the same size and position as the original pushpin icon.
    The base of the traffic light is the focal point.
    Wizz
  1. D3 with USB GPS after HIBERNATION
    By BOND007BE in forum Map Monkey
    Last Post: 11-26-2004, 02:54 PM
  2. How do I import Speedcam's into D3 1.1
    By CdRsKuLL in forum GPS
    Last Post: 10-25-2004, 08:39 PM
  3. icon question
    By robert42 in forum ME Archive
    Last Post: 09-07-2003, 07:49 PM
