Why not use Access as the import/export tool, or have I lost the plot in this thread?!
About the separators and laguages, it's a known issue in excel. Some languages use a semicolon as a separator in a 'comma separated values'-file. Just find/replace ; with , in the file with your favourite text-editor![]()
VW Mk2 Golf GTI 16V:
Kenwood KDC-W6527 HU
Silver Travla C134, Slot Loading DVD/CDRW,
256MB, VIA Epia MII 12000, Carnetix 60W, Xenarc VGA/Composite TS and a GPS Mouse
Explained better:Originally Posted by JC-S60
you see in the bugs report, me and others we have the probleme of errors with the separator in Import file....in advance GPS configuration mode.
From thing it depends according to you?
There and perhaps to edit or to change something in the file SC_DV. csv (I use that " Italy")
Thanks for info...![]()
Mauri
Mauri can you check my suggestion in the bugs thread?Originally Posted by mauri
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Downloading it now. Will test tonight and report.
Thanks again for all your hard work NM.
'94 Mazda T3500 Bus, Lilliput 7", Mouse GPS, 1GHz TC1100 Tablet PC, Inverter, HUGE Spare battery, Smart Charger, Road Runner, FreeDrive.
i seem to only have the loading in frodoproblem
good work.. looks good
Very nice indeed !
A small feature request regarding the speed cams.
When adding a camera manually you get a predefined set of speedlimits
or you could enter one manually... would it be possible to have the predefined set configurable through a .ini file ?
Another question, I assume TMC is on hold for now, but is it on hold forever because the SDK-kit (dll's) doesn't include that feature or is it because there's only 24h in a day ?![]()
Many thanks !
/M
They are already configurable now! inside the folder of the skin you're using is a SKIN.INI. If you open this file there is a section called "Add Speed Camera" that will have the following valuesOriginally Posted by Maximus
Speed1=31,3,60,60,30
Speed2=128,5,60,60,40
Speed3=27,87,60,60,50
Speed4=131,83,60,60,60
Speed5=28,167,60,60,70
Speed6=133,167,60,60,99
The last value of each (30,40,50 etc.) is the speed that will be entered. (a speed of 99 means it will show the keypad)
Once you've changed these, unfortunately you'll need to amend the images (ADD_CAMERA_DOWN.JPG and ADD_CAMERA_OFF.JPG) but it shouldn't be too difficuilt
I'm a new in this forum ! I'm from Italy .
I have a carpc with media player and Destinator 3 ...
My auto is a Alfaromeo 147 and my carpc is a Intel celeron 2.4 ,256 mb ram, hdd - 30gb laptop , mainboard Shuttle mv43vn. Touch screen Lilliput 7 " .
For Ninja Monkey , a special thank's for your work !!!!![]()
What power supply do you have? can you show me the current your power supply gives at the 5V line?Originally Posted by andreagospa
