OK, most if not all the bugs that I was alerted to have been fixed. So it's time for you all to find me a whole set of new ones!
Especially seeing as I've also added a couple of stuff and made some changes!
Code:
Version History
[v1.1.3.14 BETA 2]
*New Features*
-Import Speed Cams into Favorites
On the configuration screen, you can now choose to import all
of the speed cameras of your chosen database straight into
the FE_SPEEDCAMS favorites folder of destinator. This means
they will appear straight on the map rather than having to
wait for them to be detected before showing up.
-Custom Speed Warning
By editing the value in Settings.INI, you can have a custom
speed warning that will alert you when reach a certain speed.
-Scroll Buttons
There are now buttons on dialog screens that allow you to scroll
up and down any lists. This helps touchscreen users who find it
difficuilt to use the small scrollbar.
-Camera Warning Sounds
There is now a different warning sound for each type of camera.
Any new types of camera can also have sounds made for them
by creating a wave file and calling it Warning[x]_[TYPE].wav
and placing it in the WAVE folder.
-CdRsKuLL Skin
The popular skin by CdRsKuLL has been updated for 1.1.3 and is
now the default.
*Changes / Fixes*
-Logic mode working incorrectly
A bug was occurring where you wouldn't be notified audibly if
logic mode was enabled and there wasn't a speed specified for
the road. This has now been resolved.
-Number of satellites not displayed
The number of satellites was always displaying as 0. This is
now fixed.
-Enter Key on OSK not opening "Sort-By" dialog
This is now resolved
-Cycle Forward Hotkey
This doesn't click navigate after the last dialog. Instead it
returns to the first. To click navigate use the
FE_CLICK_BUTTON_1 hotkey.
-Global Hotkeys when embedded
An error was occurring when using global hotkeys embedded. This
should now be fixed.
-Advanced Mode
Several bugs were found with advanced mode. These should all be
resolved.
It also looks like the NETHERLANDS speed cam database wasn't named correctly on the last release, so it wasn't included in the selection list. It should be there now
Destinator 3 Frontend BETA 2 (1.1.3.14) [11.4MB]
Go get 'em!
