Page 2 of 10 FirstFirst 12345678910 LastLast
Results 11 to 20 of 91
Thread: 1.1.3 BETA(2) - Bug Reports
  1. #11
    Nov 2004
    Thanks for an excellent app, NM.
    One bug I appear to have is that the program does not exit when run standalone. Checking the Windows XP Task Manager, the prog shows "not responding". Beta 1 was fine.
  2. #12
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    The home button fails to respond when in dialog boxes. Only way to get back to map is to click the cross at top of box...
    John
  3. #13
    Aug 2004
    On the edge!
    Oh, and for some reason it took nearly 3hours to import all the speedcams into the prog ?!?
    It seemed to rip through the first 2000 and then took about 2secs for each one thereafter... :-|
  4. #14
    Nov 2004
    hello,
    is there a option to delete the frodo buttons ?
    Cu
  5. #15
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Everyone who's getting the database errors with advanced mode (comma seperated blah blah), can you try placing the attached file inside your countries folder? (Located in C:\DestinatorApps\Frontend_Prev\SC_DB\)
    Replace the file that's already in there and see if it works.
    Attached Files Attached Files
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  6. #16
    FLAC mauri's Avatar
    Jan 2004
    No , doesn't work, same identical error.
    I have replaced in the folder SC_DV , in sub-folder of my country " Italy ",the originates Schema.ini with yours new post,but nothing to do.
    Edit:its possible to edit in future new skin the button of size H 60 pixel instead of 40 ?
    Hi have tested whit the new beta this size of button but one error (edit the correct value of skin.ini).
    Tested whit old beta work correctly in this size...hi have make the add new button skinning ok,riedit the skin.in in the skin folder but error :
    Number: 9
    Description: Indice non compreso nell'intervallo
    Source: Load_Skin_Settings
    Version: 1.1.314
    HelpContext: 1000009
    HelpFile:
    LastDllError: 0
    Thanks Ninja for your patience....
    Mauri
  7. #17
    Aug 2003
    Warrington, UK
    Quote Originally Posted by mauri
    Number: 9
    Version: 1.1.314
    HelpFile:
    LastDllError: 0
    Mauri
    Try this one instead
    For the skin, can you post the SKIN.INI that you're trying to use?
  8. #18
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by Ninja Monkey
    Yes, you have found the solution.
    Now works OK.
    This way' it seems also resolved the problem to add the speed with the button " add new speed" in D3.
    Good Ninja.
    For the skin, I have to end of settings some buttons in skin.ini, tomorrow as soon as ready (I hope) if you want, I post you the file Skin.ini in the forum or the complete skin to your e-mail (send me her in PM message)
    The skin and' type the other, with buttons great, but different graphics, as I prefer me.... and size H 60 of buttons.....
    Mauri
  9. #19
    Belgium - Oostmalle
    Mauri
    Also getting the error, even after replacing the "schema.ini" in the Belgium folder ... Importing doesn't work (keeps saying Please wait, but nothing happens ...)
    When cancelling import and thus resuming in Destinator, I get an infinite loop concerning the GPS (BU-303) with following error :
    Error Details:
    Number: -2147217900
    Description: Syntaxisfout (komma) in query-expressie val(longitude) < 0,073 AND val(longitude) > -0,073 AND val(latitude) < 0,073 AND val(latitude) > -0,073.
    Source: Check_For_Camera
    Version: 1.1.314
    HelpContext: 5003000
    HelpFile:
    LastDllError: 0
    Car : Hyundai Tucson
    Carpc :
    Lilliput 7" touchscreen indash 90% done
    PSU : M2-ATX
    Epia M10K /512DDR/80GB Maxtor
    Software : Windows XP Pro 100% done
    RR with DigitalFX skin
    In car : 80% done
  10. #20
    Nov 2004
    France
    Hello,
    Thanks for your mauris' propositions, Before it could work if Windows' preference set as English USA (not easy for a french)
    I get another BUG in my car : Times for messages are too short
    In English : take second exit in 200 M give in fact : "cond exit in 200 M"
    In french with long messages :
    Prendre la deuxième sortie du rond point après 200 M give : "point après 200 M"
    I also tried SWISS Programm Mediacruiser (use Destinator3 whithout frontend)
    Speech Time is good, can use SIRF but cannot display speed !...
  1. Bug Tracking (sorry long but please read)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-22-2005, 04:12 PM
  2. 1.1.3 BETA - Bug Reports
    By Ninja Monkey in forum Map Monkey
    Last Post: 11-29-2004, 04:48 PM
  3. Bug Reports 1.09
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-22-2004, 11:24 PM
  4. Bug Reports
    Last Post: 10-16-2004, 01:25 AM
  5. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 05:32 PM
