Page 4 of 10 FirstFirst 12345678910 LastLast
Results 31 to 40 of 91
Thread: 1.1.3 BETA(2) - Bug Reports
  1. #31
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Can everyone having problems importing / adding cameras / strange errors with advanced mode try this Schema.ini instead?
    You need to place it inside C:\DestinatorApps\Frontend_PREV\SC_DB\[NAME OF YOUR COUNTRY]
    Attached Files Attached Files
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  2. #32
    Belgium - Oostmalle
    Ninja Monkey,
    Now importing works like a charm, but when enabling speed camera alerts in the configuration, I still get a looping error in D3. Taskmanager is the only way to stop it. If I don't enable that option, everything works well. (even in Neocar Media Center)You did a very well job sofar. Keep up the good work. Here is the error I get :
    Error Details:
    Number: -2147217900
    Description: Syntaxisfout (komma) in query-expressie val(longitude) < 0,073 AND val(longitude) > -0,073 AND val(latitude) < 0,073 AND val(latitude) > -0,073.
    Source: Check_For_Camera
    Version: 1.1.314
    HelpContext: 5003000
    HelpFile:
    LastDllError: 0
    What could this mean, and any suggestions to resolve this?
    Car : Hyundai Tucson
    Carpc :
    Lilliput 7" touchscreen indash 90% done
    PSU : M2-ATX
    Epia M10K /512DDR/80GB Maxtor
    Software : Windows XP Pro 100% done
    RR with DigitalFX skin
    In car : 80% done
  3. #33
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by gyro
    Ninja Monkey,
    Error Details:
    Number: -2147217900
    Version: 1.1.314
    HelpFile:
    LastDllError: 0
    Your file in the folder " Favorites" name FE_SpeedCam.dat its blanck before launching the " Import "?
    I have see that if not white in original (no text write, open whit notepad to view) "Import " doesn't write anybody data.
    You have the GPS connected ?
    Disconnect this and launch the Import.
    Mauri
  4. #34
    Belgium - Oostmalle
    Mauri, the import is OK, with or without GPS connected. The problem is situated afterwards and occurs only if I enable Speed camera alerts.
    Carpc :
    PSU : M2-ATX
    In car : 80% done
  5. #35
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Same problem. item 1) yesterdays post
    Can anyone answer item 2) in yesterdays post
    How D3 gives incorrect voice commands at roundabouts ?
    Wizz
  6. #36
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Tried the new version of D3 on my laptop with no GPS and the default map and the OSK did not work... I notice Mari also said he had the same problem.
    Terran
  7. #37
    Low Bitrate Prem's Avatar
    Oct 2004
    West Sussex UK
    Ninja Monkey
    Skin.ini file.
    Changing the values for the AddressPos within the Info Bar group, does not change the on-screen position.
    Cheers
    Prem
    Re-boxed Dell Optiplex GX110 PIII 733 256Mb RAM
    Modified Sproggy PSU
    Custom made automatic start-up/ shut-down controller
    Dual 2.5" HDDs
    Laptop DVD Reader
    D-Link FM Radio
    5" PSOne LCD
    Installed and working. 75% complete.
  8. #38
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by ccsnet
    Terran
    is thing happens only if I launch Destinator with the utility of configuration skin, settings, etc.
    Instead if I directly launch D3 or embedded Mediacar all OK.
    There and however a problem surely with the OSK to be resolved.
    Mauri
  9. #39
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    Quote Originally Posted by jlicence
    Hi Ninja
    Bit of a strange bug for you here! Exactly the same as Seth was having with the previous BETA, where the OSK would not work when planning a route, until the upper address window has been closed by clicking [X].
    I've done some testing on this, and for some strange reason, when I run D3 from a shortcut on my desktop, I get this problem. When I run from the shortcut in the DestinatorApps folder it works fine.
    I've tried recreating the shortcut, but it doesnt help! It also does not matter if I have Full Screen, maximised or normal windows.
    Hi NM
    All these days I was playing with the latest BETA and I have some feedback for ya. Before I start I state that I didn't do the font mod at any file just in case that was the source of the problems. Here we go...
    1) As jlicence said the non-working OSK problem still exists. The weird about this is that there is no clear pattern on when it does work and when it doesn't. I'm afraid I cannot narrow it down.
    2) The GPS refresh rate (and performance) is not good. Slow updates, no signal when passing from streets where before 10 minutes I got 5 sats full, generally eratic behavior. My GPS is a Deluo serial NMEA GPS and the "Use advanced GPS Mode" is unchecked (the same happens when it is checked).
    Here I must say that I ruled out the possibility it is my GPS's fault because it works perfectly with 1.1.2 which btw is the most stable and reliable release.
    3) Sometimes the performance when navigating is not good. I noticed wrong turn directions (even when the ploted route is correct), it does not announce the meters-to-go before direction change etc. Seems like something is not working right. I use the same maps as in 1.1.2 where I have no such problems at all.
    4) The BETA state announcement at the start of the program prevents it from embbeding with Frodo. Other than that interaction with Frodo worked for me without a problem.
    5) For all you guys who get an "Error No 7 : Out of memory" I found that at least for me appeared because I changed the folder name C:\DestinatorApps to C:\DestinatorApps1 due to the different versions testing.
    My system is :
    P4-ITX
    Celeron 1.7GHz
    512 MB DDR
    40 GB disk
    My installed software is :
    Windows XP with SP1a
    .NET Framework 1.1 with SP1
    WMP 9
    Frodoplayer 1.09 with all the patches installed
    DirectX 9.0c
  10. #40
    Oct 2004
    West Sussex UK
    Ninja Monkey
    There is a bug with hotkeys 31, 41 and 42 when running emmbeded or full screen. It appears that the mouse click that you have programmed, is clicking in the wrong area (I think this is because the top blue part of the normal window is missing).
    Edit: Ninja Monkey... I'm talking bollox. This was entirely my own doing!!! Sorry.
    Also, I want to increase the font of the lists to a rather silly size (about 36pt) this also causes problems with hotkeys 41 and 42 because the size of the button has changed. Can something easy be done or do you want to tell me that 30pt is the biggest I can have.....
    Cheers
    Prem
    Dual 2.5" HDDs
    Laptop DVD Reader
    D-Link FM Radio
    5" PSOne LCD
  1. Bug Tracking (sorry long but please read)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-22-2005, 03:12 PM
  2. 1.1.3 BETA - Bug Reports
    By Ninja Monkey in forum Map Monkey
    Last Post: 11-29-2004, 03:48 PM
  3. Bug Reports 1.09
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-22-2004, 10:24 PM
  4. Bug Reports
    Last Post: 10-16-2004, 12:25 AM
  5. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 04:32 PM
