Page 6 of 10 FirstFirst 12345678910 LastLast
Results 51 to 60 of 91
Thread: 1.1.3 BETA(2) - Bug Reports
  1. #51
    Low Bitrate Shayughul's Avatar
    Jul 2004
    Minot, ND
    Quote Originally Posted by yunusyu
    Sorry to bring another thing into attention, it seems there are enough problems.
    I dont see it on this thread , so i will assume its new:
    The ETA and ETR next to the music control buttons do not take into account taht i slowed down...on the buttom the ETA adjusts if i am driving slow, when on he top the ETA starts counting negative minutes traveled after it finished counting the minutes it takes me to travel...confused? letr me try again:
    1. I chose a destination
    2. ETA: 12:30 am
    3. I am stuck in traffic
    4. the ETA on top still says 12:30
    5. ETR goes down to 0mins
    6. I am still in traffic
    7. now the etr is counting 0:06- mins
    yeah, well hope i am not the only one experiencing this
    btw, the counter on the bottom is fine
    While I also have this issue I have also noticed that if I have a route planned. And at some point stop for gas or food or whatever....Once the program has been closed and opened back up....it remembers the route ok but all I get for ETA and ETR are ?....for some reason it does not re-calc them once the program has been closed and opened again.
    I am also having the OSK issue of not being able to type with it at all.
    Edit: Also not sure if this is a bug or a feature request....but everytime I open the app stand-alone...not embedded. I have to maximize the app every time. Not a big deal...but I thought I would pass it along.
    Newbie Bulldog 1.0's Avatar
    Jan 2004
    Brussels,Belgium
    Hi NM,
    When I have Speed Cam detection enabled, I get slowdowns whenever i get in the neighbourhood of a speedcam. The CPU hangs at 100% for about a minute, then i get the audio warning and D3 tries to display the visual warning. The visual flashes by, not even a second on screen.
    After that D3 works normally untill the next speedcam when everything gets repeated.
    I imported the speedcams in favorites, have advanced GPS enabled en Logic off.
    Thx for the prog
  3. #53
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Quote Originally Posted by Bulldog 1.0
    Hi NM,
    Thx for the prog
    I think this might be because there are so many entries in your favorites folder...although there are issues with CPU and searching the CSV file (which are now fixed in my dev version)
    Try clearing the speedcam favorites folder down (easily done by trying to import another countries database in non-synchronise mode then clicking abort) and see if it still occurs
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  4. #54
    Newbie mazda626's Avatar
    Dec 2004
    Netherlands
    Is it possible to turn of the message that says that you are using a beta version etc.. ?
    Cause, i 'd love to test it, but when this message appears everytime it's quit anoying.
  5. #55
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by Ninja Monkey
    Thanks, I'll look into the CPU usage
    I'm pretty sure if you go into the navigate to POI dialog you can tick the checkboxes next to all the categories you want displayed on the map, just like you can with favorites.
    @ Ninja, for news for you.. seems to be worse in the birds eye view...
    Quote Originally Posted by ccsnet
    Thats right and then you can go to... I've used it before.
    No, what I ment was just displaying them any way to map the map view a little less bland.
    Terran
    PS: I may be wrong so I'll test 1st thing
    @ Ninja... yep that worked... never had that in v2.
    Quote Originally Posted by mazda626
    I'd say no because it would not be a beta then and I can understand why Ninja has done it... anoying although it is.
    Terran
  6. #56
    Newbie Harrie Coolen's Avatar
    Nov 2004
    Dordrecht, The Netherlands
    createGPS thread error
    Hi, what does the error "GPS Thread is not created..." message mean?
    I've tested my gps unit and it works, could it be a software error?
  7. #57
    Aug 2003
    Warrington, UK
    Quote Originally Posted by Harrie Coolen
    It means you're probably using windows 98
  8. #58
    Nov 2004
    Thumbs up gpd thread error
    thanks for the reply, i've solved the problem with installing windows XP Pro!
    And now everything works great!!!
  9. #59
    Jul 2004
    This is some very nice work. Thanks for sharing.
    When I launch D3 in stand alone mode or from Frodoplayer I get the following error.
    Error Details:
    Number: 6
    Description: Overflow
    Source: Load_Settings
    Version: 1.1.314
    HelpContext: 1000006
    HelpFile:
    LastDllError: 0
    This only happens when my GPS is running in siRF mode. Here's the relavant part of the config file.
    [Advanced GPS]
    //NMEA Receivers only
    UseAdvanced=NO
    COMPort=4
    COMBaud=38400
    Protocol=SIRF
    I'm using a BU-303 receiver. Despite the error message the software does appear to be working. When the GPS gets a fix it does report my position correctly. Of course I'm still testing my rig indoors so I haven't actually seen what happens once I start moving...
    -momanz
  10. #60
    Belgium - Oostmalle
    Try setting it to com4/4800baud/NMEA. Works allright for me this way
    Car : Hyundai Tucson
    Carpc :
    Lilliput 7" touchscreen indash 90% done
    PSU : M2-ATX
    Epia M10K /512DDR/80GB Maxtor
    Software : Windows XP Pro 100% done
    RR with DigitalFX skin
    In car : 80% done
  1. Bug Tracking (sorry long but please read)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-22-2005, 03:12 PM
  2. 1.1.3 BETA - Bug Reports
    By Ninja Monkey in forum Map Monkey
    Last Post: 11-29-2004, 03:48 PM
  3. Bug Reports 1.09
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-22-2004, 10:24 PM
  4. Bug Reports
    Last Post: 10-16-2004, 12:25 AM
  5. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 04:32 PM
