cant seem to get it to work in SiRF mode older version is fine but this one tells me the com port is busy
@ Ninja Monkey
Really hammered it this week.. CPU still getting killed by it when running how ever found the speed camera warning very good if a little behind because of the GPS, SiRF support is definatly needed but I know you have that in your scope at some point.
But.... heres another one of those not a bug but is it sort of things.
Sat a traffic light junction with a speed camera just up the road. Now thats ok but the satelights kept changing so it thought it was moving a meeter or two so the waring kept comming up... ok for me as I was listing to the CD at the time but what if you where listing to mp3s at the time.
I think some kind of check to make sure that a considrable amount of movment is happering rather than a meeter or so before re-showing the warning again.. just a thought like I say.
It was intresting to find that the 'later installed' cameras where being picked up where by the old ones where not... intresting.
Lastly and a bit OT is there any way to get a POI icon on the map showing where the cameras are as well as the waring... this could just be me before I get flammed as I have been 'using' rather than 'playing'.
Terran
Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall returnThe car
SiRF mode is not supported in advanced mode and you need to change the reciever set up... do aOriginally Posted by skydiver
and you should find what you need.
Terran
done that with SiRF Demo
outputing Sirf at 38400 com2
are there any other settings i have to change ?
this is all i did with v3.1 and it word fine
Originally Posted by ccsnet
Destinator 3 For PC! - http://www.map-monkey.co.uk/
where is the FM ?
for a beta? good luck with that
"SiRF mode is not supported in advanced mode".... I thought ?Originally Posted by Ninja Monkey
Terran
That's right, his response to you telling him it's not supported was that he's enabled it...so I re-quoted what you saidOriginally Posted by ccsnet
im lost please explane "advanced mode"
