Page 8 of 10 FirstFirst 12345678910 LastLast
Results 71 to 80 of 91
Thread: 1.1.3 BETA(2) - Bug Reports
  1. #71
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Aren't we all...
    Basically if you want to use SiRF mode in 1.1.3, you'll have to disable "Advanced GPS" (Which means no speed camera detection, speed display and a few other things).
    Then you can go into D3 as normal and tell it you're using SiRF, set the COM port etc... just like 1.1.2
    However, if you want Advanced Mode - you'll have to change your device back to NMEA and then in the FRONTEND configuration enable advanced mode and choose your com port here instead - this will then ignore D3's input.
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  2. #72
    Constant Bitrate skydiver's Avatar
    Nov 2004
    southampton (UK)
    i see the light
    thanks
    Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
    The car
  3. #73
    Variable Bitrate Goose's Avatar
    Dec 2002
    Europe
    Error Details:
    Number: -2147024770
    Description: Automation error
    The specified module could not be found.
    Source: Init_Hotkeys
    Version: 1.1.314
    HelpContext: 1000440
    HelpFile:
    LastDllError: 0
    Get this when I start Destinator.
    Pushing Ok and it works...
    :roll
  4. #74
    Constant Bitrate naveedh's Avatar
    Oct 2004
    hey ninja, werer can i configure that when i do route --> address, i have to hit enter and then select zip-street. I want zip-street to be default. How can that be done?
    Also can i change zip to say postcode instead as zip is american, so i want it to say post code-street?
  5. #75
    Aug 2003
    Warrington, UK
    Quote Originally Posted by naveedh
    I think perhaps you have to ask YET AGAIN for that feature...I didn't quite hear you the first 15 times you asked! I already told you I'd implement it!
  6. #76
    Dec 2002
    Europe
    I think best to let NM do finish beta 2 and make a full version of software. The cosmetical things like that, should be lived at the end...
  7. #77
    Oct 2004
    ok, sorry but i have found a fault in the latest beta release that i though i would let you know. The enter key doesnt work to get sort by dialog even though you said in the version history.txt that its been resolved but it hasnt.
  8. #78
    Aug 2003
    Warrington, UK
    works fine for me, i'll look into it
  9. #79
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by Ninja Monkey
    Also to me the key Enter doesn't work in the OSK, only from the principal icon of D3
    Mauri
  10. #80
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    That's right, his response to you telling him it's not supported was that he's enabled it...so I re-quoted what you said
    Ok... sorry
    Terran ( Now back in his box lol )
  1. Bug Tracking (sorry long but please read)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-22-2005, 04:12 PM
  2. 1.1.3 BETA - Bug Reports
    By Ninja Monkey in forum Map Monkey
    Last Post: 11-29-2004, 04:48 PM
  3. Bug Reports 1.09
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-22-2004, 11:24 PM
  4. Bug Reports
    Last Post: 10-16-2004, 01:25 AM
  5. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 05:32 PM
