Page 1 of 10 12345678910 LastLast
Results 1 to 10 of 91
Thread: 1.1.3 BETA(2) - Bug Reports
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    GoGoGo
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Constant Bitrate ThEScReW's Avatar
    Nov 2004
    Kortrijk/Belgium
    Still have that same problem :
    http://www.mp3car.com/vbulletin/atta...tid=6882&stc=1
    But the softwrae doesnt shut down now. Further it works fine (maybe ETR a little bit move it to right)
    Aug 2003
    Warrington, UK
    Quote Originally Posted by ThEScReW
    You need to download and register TABCTL32.OCX! Didn't you do that last time?
    You can move the ETR yourself if you dare have a play with the skin.ini
    Nov 2004
    Kortrijk/Belgium
    Quote Originally Posted by Ninja Monkey
    I downloaded the file, register how? Where do i put the file?
    Found the skinning in visual studio thx
    Aug 2003
    Warrington, UK
    Put it in your WINDOWS\SYSTEM32 folder and type the following at the RUN prompt.
    REGSVR32 C:\WINDOWS\SYSTEM32\TABCTL32.OCX
    Nov 2004
    Kortrijk/Belgium
    I just found it on the forum :-) THX it works just fine now and indeed as smiley says : the speed font isn't the best...
    Aug 2003
    Warrington, UK
    Everything can be customised!
    Don't be saying skinning dislikes are bugs! This threads gonna be big enough as it is!
    FLAC mauri's Avatar
    Jan 2004
    I have made the first tests of the Beta2 on the home PC.
    I have found 2 errors.
    Error 1 - launch " Configuration Mode "
    Advanced GPS menu
    Set to " database = Italy (my Country)
    ADD/Sincronise button
    I choose " OK "
    Inporting load departs "... then immediately later:
    Error Details:
    Number: -2147467259
    Description: Il separatore di campo nella specifica dei file di testo
    corrisponde al separatore decimale o al delimitatore di testo.
    Source: Import_SCDB
    Version: 1.1.314
    HelpContext: 5003441
    HelpFile:
    LastDllError: 0
    Error 2 - with D3 I activate:
    If clik on the button Add-Speed button and then one circle with speed.
    Error:
    Number: -2147467259
    Source: Add_Speed_Camera
    Version: 1.1.314
    HelpFile:
    LastDllError: 0
    (already signalled with the beta 1 this error, impossible click on whatever circle of speed already set, always error )
    EDIT: how to do for memorize a new speed with the small keyboard and to confirm ?
    I use D3 for test not embedded , stand-alone mode,original your file download, whit CDR skin ( edit: the file SPEED_.psspimage in your Classic skin NOT PRESENT in CDR skin, whi? Important for correctly use of skin in D3 )
    Thank for the best work NM
    Mauri
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Skinning dislikes are bugs!
    Terran
    ( Well some one had to )
    Nov 2004
    France
    Exactly the same error than Mauri :
    Error Details:
    Number: -2147467259
    Description: Le séparateur du champ de spécification du fichier texte est identique au séparateur décimal ou au délimiteur de texte.
    Source: Check_For_Camera
    Version: 1.1.314
    HelpFile:
    LastDllError: 0
    If i disconnect the GPS, Error disapear ! but...
    If i change decimal separator point ==> comma, i get another error, this is not the sol.
    [B]In fact the error occurs only in advanced mode when Enable Speed Camera Alerts is selected.[/B]
  1. Bug Tracking (sorry long but please read)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-22-2005, 04:12 PM
  2. 1.1.3 BETA - Bug Reports
    By Ninja Monkey in forum Map Monkey
    Last Post: 11-29-2004, 04:48 PM
  3. Bug Reports 1.09
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-22-2004, 11:24 PM
  4. Bug Reports
    Last Post: 10-16-2004, 01:25 AM
  5. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 05:32 PM
