Results 1 to 10 of 13
Thread: Speed Camera FAQ ?
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Speed Camera FAQ ?
    All,
    Any chance some one can post a simple how to do UK speed camera intergation... using the beta 2 release .
    Searched loads of threds and found no clear way of doing it... and I am suere I am to the only one to ask.
    Then can it be a sticky ?
    Cheers
    Terran ( Another newbie question )
    Quote Originally Posted by ccsnet
    All,
    Cheers
    Am I missing something here. I thought that the UK speedcameras were already in the latest release ???
    Jan 2003
    Quote Originally Posted by Matthew230
    I may be.... don't you need to import a file or some thing ? Noticed some near me are not displayed so I am gussing its me at fault...
    Terran
    When I've used the Beta releases, it just asks which Speed camera database you want to use.
    If you are using the older versions, (ie the original D3 + upgrade), then visit here.
    Download Destinator 3 UK Speed Camera Pack HERE
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Terran
    ok
    Speed camera detection in my frontend is totally seperate to destinator. When a camera is first detected or when you add a camera manually, it is automatically added to a favorites folder inside destinator called "FE_SPEEDCAMS". This enables the camera to then be displayed on the map. Deleting / adding items to this folder will not affect detection at all - it is simply used for displaying the cameras.
    So, you won't be able to actually see the camera displayed as an icon on the map until you've driven by them at least once. (Yet when you are approaching one for the first time you will be notified all the same)
    If you really can't live with that, as of BETA 2 there is an 'import to favorites' button on the config screen which will wade through the entire camera database and add each one to the favorites folder, and so all will be displayed on the map without having to detect them first. (Because the destinator SDK isn't the best coded library ever this may take a while on large databases)
    Basically, if speed camera detection and advanced GPs are enabled and cameras aren't being detected then they're not in the database. I'm not sure how up to date the files are - I may replace the UK one with the latest pocketgps data.
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Jan 2003
    Quote Originally Posted by Ninja Monkey
    ok
    Tar, thats what I was looking for.
    Terran
    Newbie Henriko's Avatar
    Jun 2004
    Norway
    Hmmm... Just tried to import the speedcam-database, but im just getting this error:
    Error Details:
    Number: -2147467259
    Description: Feltskilletegnet angitt for tekstfilen er det samme som desimalskilletegnet eller tekstskilletegnet. (Translates to something like this: Section-punctuation mark stated for the textfile is the same as decimal-punctuation mark or text-punctuation mark)
    Source: Import_SCDB
    Version: 1.1.314
    HelpContext: 5003441
    HelpFile:
    LastDllError: 0
    Doesn't make any sense to me either... Just a plain 1.1.3 beta2 install, no fuss... Thanks for any help, as this will improve my economy dramaticly
    Aug 2003
    Warrington, UK
    That error has been posted many, many times already in this forum
    Jun 2004
    Norway
    Ups... Sorry, i've read through a lot of posts, and havnt come across it :P My bad Guess it's not solved?
    Edit: I found it now, it was (very well hidden) on the first page of the sticky bug-reports thread *blush*
    Well... Iva replaced my schema.ini file, so now I can import the database correctly, but it still gives me that "Number: -2147217900
    Description: Syntaksfeil (komma) i spørreuttrykket val(longitude) < 10,5220683333 AND val(longitude) > 10,3760683333 AND val(latitude) < 59,2827283333 AND val(latitude) > 59,1367283333
    Source: Check_For_Camera
    Version: 1.1.314
    HelpContext: 5003000
    HelpFile:
    LastDllError: 0" error that has been reported...
    Couldnt find a fix for this when i skimmed trough the post, so ill consider this as WIP Thanks for not -flaming me
    Aug 2003
    Warrington, UK
    Hey I considered it, you were lucky this time
    No that is still a problem with language settings and the way I've hard coded some variables in to the camera detection.
    In the new beta I'm moving away from CSV files and using full databases instead, which should hopefully solve the problem!
  1. Replies: 29
    Last Post: 04-09-2007, 06:44 PM
  2. Replies: 23
    Last Post: 12-29-2005, 10:05 AM
  3. Speed Camera Alerts for Destinator 3.1
    By Matthew230 in forum GPS
    Last Post: 10-27-2004, 08:33 AM
  4. Speed camera detection software on laptop
    By rickyaswell in forum LCD/Display
    Last Post: 08-26-2004, 08:13 AM
  5. Replies: 11
    Last Post: 04-12-2004, 06:10 AM
