Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: Onscreen keyboard
  1. #21
    gti
    gti is offline
    Dec 2004
    ive tried all the above and still no luck.
    Trev
  2. #22
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Quote Originally Posted by gti
    Trev
    You seem to be having a different problem, the keyboard is actually clickable for you (seeing as the home button works) but it's not sending the keys to the dialog...
    I'm guessing my code to find the dialogs handle is either failing or mistaking it for some other application you have running...can you try exiting out of absolutely everything you can (including hidden processes in task manager) and trying again?
    Worth a shot
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  3. #23
    gti
    gti is offline
    Dec 2004
    Ninja Monkey,
    Ill give that a go in a bit, im at uni at the mo. Ill shut down all background stuff and let you know how it goes.
    Trev
  4. #24
    gti
    gti is offline
    Dec 2004
    Ninja Monkey the problem is solved. Im running sygate firewall on both internet pc's, and for some reason its screwing with the osk. So i turned this off for a sec and all is solved. Clearly i will have no need for a firewall on my car pc
    Regards
    Trev
  5. #25
    Dec 2004
    The Netherlands
    Yeah, I can confirm this.
    I was having the same problems with the onscreen keyboard, but after disabling sygate firewall it works like a charm.
  6. #26
    Aug 2003
    Warrington, UK
    Excellent! Glad you got it sorted (and it doesn't mean any extra coding for me!)
  7. #27
    Nov 2004
    Surrey, UK
    My osk works if I launch destinator from the button in frodoplayer, but not from the desktop shortcut.
    bye bye desktop shortcut!
    thanks for all the hard work
  8. #28
    May 2004
    Copenhagen
    Well it seems that mine did not work either, just made a sound when i tried to press the buttons. Turned off the Win Xp SP2 firewall and it worked like a charme...
    Damn i hate SP2
  9. #29
    gti
    gti is offline
    Dec 2004
    so even xp fw can screw things up... hmmm wonder why a firewall causes this. You got any ideas Ninja Monkey??
    Trev
  10. #30
    Aug 2003
    Warrington, UK
    Under 1.1.2 the frontend talks to the D3 client through a TCP/IP connection, so I can see why a firewall might block it...
    however, the last few betas are complete single applications and don't use anything like that at all! Why a firewall would block API calls is beyond me
  1. Laptop keyboard to the PS2 port....
    By claylong in forum General Hardware Discussion
    Last Post: 09-22-2007, 07:29 AM
  2. 2 part question (keyboard hacks)
    By chuckctv in forum Input Devices
    Last Post: 09-07-2004, 09:24 PM
  3. mini keyboard
    By Alphared in forum Input Devices
    Last Post: 07-27-2004, 11:32 AM
  4. Hows about this for onscreen keyboard?
    By phil.45 in forum General Hardware Discussion
    Last Post: 07-21-2002, 01:00 PM
  5. Disabling BIOS keyboard error?
    By Squeezer in forum General Hardware Discussion
    Last Post: 02-02-2001, 09:29 AM
