Results 11 to 20 of 21
Thread: COM port busy
  1. #11
    Dec 2004
    Sorry to hijack
    I have install xport2 and compass - working perfect emulating for the oziezplorer software
    However the destinator software only allows me to use normal ports, the emulated ports are not there, and the xport software doesnt allow you to emulate on normal ports
    any help apprechiated, btw all these programs are the best,,, keep up the good work
    i only found out about them at lunch time today, and they are all workng great exept for the little issue above
    thanks
    dave
  2. #12
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    With a Hex Editor you can edit Destinator.ini and change the comport.
  3. #13
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Please remember guys, if you're using advanced mode it doesn't matter what port you have destinator set to, because it won't use it!
    You need to specify what port you are using in SETTINGS.INI (or Frontend config) and not through destinator...This is probably where most of you are going wrong.
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  4. #14
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Hey Ninja Monkey I will give you the detail error later when I run the app again.
    Here is the basic what happen.
    I didn't use D3 to set the COM port (in D3 it is currently on COM1)...
    I use Front End configure tool to set COM port. It is set to use COM6 (created by Xports/gpsGate).
    When your front end is launch, it give an error about ActiveX something and said to send you a message.... can remember exact error. ...
    With gpsGate it work fine same connecting method as Xport2.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  5. #15
    Aug 2003
    Warrington, UK
    It possibly is something to do with destinator - before advanced mode is activated, for a split second destinator will try and connect to its configured com port...try changing destinators com port away from 1 if it's not already
  6. #16
    Jul 2004
    NL, Druten
    tomorrow i have a day of... hope it's gonna work out..
    I saw there is no uninstall with Xport. regmon will do it, if i install it at another pc I guess??
  7. #17
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by TheKingPlaza
    If you want to uninstall Xport, just delete the 2 Xport files and reboot the machine.
    Anyway, I got them all working.
    - Compass + Xport2 for COM port for virtual port and nice little compass.
    - Routis connect to Xport virtual port.
    - D3 Betta 2 connect to Xport virtual port with Advance mode.
    all working perfect.
    My previous problem: I was still using D3 betta 1.
  8. #18
    Jul 2004
    NL, Druten
    Guys, you're great..
    thanxs 4 all the help.. works fine now
  9. #19
    Maximum Bitrate Mañana's Avatar
    Jul 2004
    Sweden
    where to get xport2? :S
  10. #20
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
  1. anyone using FIR port on EPIA M board?
    By stimps in forum Input Devices
    Last Post: 04-25-2009, 10:29 AM
  2. serial port to game port adapter wiring
    By asif in forum General Hardware Discussion
    Last Post: 08-17-2006, 05:47 PM
  3. Com port service/app for digital IO
    By momanz in forum Software & Software Development
    Last Post: 12-03-2004, 02:57 PM
  4. USB Serial Port Adapter Troubles
    By bLindmOnkey in forum General MP3Car Discussion
    Last Post: 10-14-2004, 12:29 AM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
