Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: COM port busy
    Jul 2004
    NL, Druten
    COM port busy
    I know this has nothing to do with D3 but i do ask the question though..
    I tried to duplicate my COM port with Xport.
    Here is how i tried to install/setup this..
    My GPS runs @ COM3
    startup xport and checked COM3 as input and COM 7/8/9 as output..
    But now D3 wont find my GPS.it wil show my current position but freezes as it shows the first screen
    So i go to GPS setup and select COM3, then it works again, but gat a message port busy. When set the addon (camera/speed) i get an error: port busy.
    does this meens my gps doen't alow to duplicate the com port or do i miss something? Maybe i have to use another program? I tried to @ xport but that didn't make me any
    Also tried to but that that didn't help also
    please help me out here..
    n00b 4 life mp3oplecarrier's Avatar
    Dec 2003
    Chatham, UK
    Quote Originally Posted by TheKingPlaza
    It didn't make you any (huge bouncing boobs)?
    ....Yes, I know it has a stupid name, those crazy Japanese!
    Constant Bitrate ThEScReW's Avatar
    Nov 2004
    Kortrijk/Belgium
    same problem wwith a friend of mine !
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Advanced GPS mode takes control of the COM port away from D3 - so going into D3's own COM port setup screen isn't going to do anything anyway.
    Are you sure you went back into the D3 Frontend configuration and changed the com port there?
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Try XPort2. Uninstall xport first. Install xport2. Start the compass, set it to COM3. Start D3 and set it to one of the xport2 output ports. You might have to HEX edit the destinator.ini file to set the COM port though.
    Dec 2003
    This thread might be connected to my problem... this is the info as i've posted in another thread but with a different title.
    Also if anyone is using Rayming TN-200 USB GPS MOUSE with d3 please share info.
    Thanks for the info, the OS in the carputer is win me.. (i did the testing in my home comp)...
    and it does work on windows ME (the D3 FE 1.3 P2) .. but i have 2 errors coming when i close the program , or while using it...
    1)"~Vtsoundmachine->soundthread is not closed" - this error is a message box with "ok" button which doesnt disappear and due to it i cant close the app (i shut down windows and get rid of it).
    2) i got a TripNav GPS mouse, which uses a virtual com port. now when i installed it, it took com port 3 , as the USB->serial port. and D3 recognized only com port 1, and 2 and there was no 3 (its a combobox with only recognized ports).
    So i've set in my computer (its driver has an option) its port to 1, removed com port 1 (its virtual) and restarted, when the comp got back up, it was 1 alright (the USB -> serial), what was com port 1 became com port 5. i've ran d3 and it recognized ports 1,2 and 5 (yes!) BUT .. it didnt detected the GPS. my question is this: if the gps isnt locked , it wont detect it? (cant be...)
    or maybe someone with such knowledge can enlighten me.
    3) when i open the Hebrew map, the fonts werent in hebrew (gibbrish... unknown) , how do i change them... couldnt find an option doing so. I've changed the map to the English one meanwhile.
    Thanks again ,going one step at a time...
    NM rock..
    Cheers, yours, X. The link: http://xmen4u.tripod.com/ Click below
    XMen's CarPC Website
    XMen
    View Public Profile
    Send a private message to XMen
    Find More Posts by XMen
    Add XMen to Your Buddy List
    Today, 12:06 AM #7
    XMen
    Posts: 23 more about the gps problem
    well using GPS info (a program which scans the com ports that came with the GPS (and can be downloaded from the rayming website) , and allows you to use the GPS to get coordinates , WAS/EGONS , COLD START... ) it detects the gps on the right com port1, and gets the coordinates, and all.
    but D3 F.E doesnt find it on com1... though its there. (in the right baud rate, and i've even tried playing with it)..
    I get all the time "GPS thread isnt not created" , more over, i tried in the configuration setting the com port to 1... also it didnt help.
    tried setting it to Sirf and not to nmea..
    please , help is needed
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Here ya go ... Xports and other problem solve.
    Xport2 virtual COM ports
    I can use D3, but can't use the advance mode.... didn't have time to play with it yet... the MPH display showing "NOT IMPLEMENT" but if I disable the Advance Mode, D3 work fine with Xport2 virtual COM port.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Sep 2003
    Beach City, Socal
    I try it but D3 still having problem in advance mode (fine in standard mode).
    If no Xport2/Compass, D3 fine.
    With gpsGate, D3 fine. But routis not working 100%
    With Xport2/Compass, Routis is fine, but D3 having problem in Advance mode.
    Dam ...
    Dec 2003
    ok..
    Hi ,
    Thanks again for your info... though i got several questions and idid a search and found the link to xport http://curioustech.home.insightbb.com/xport.html
    though it doesnt work for me... more over couldnt understand whats the difference between xport and xport2, gpsgate and what is the main idea behind replicating the com port.
    BTW, does your gps is a rayming tn-200 alike?thanks again, awaiting, X
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by XMen
    Hi ,
    Hey XMen, if you follow the thread from the link I post earlier, you will get some idea.
    Can you connect to the GPS COM port by using Hyper Terminal? Try that to see if you can see the data stream.
    - Xport is the first version. It doesn't work with Hibernation. You have to shutdown all connection to Xport's virtual COM port before going hibernation. It can connect to the GPS COM port via a helper application (Hyper Terminal or Street and Trips/Street Atlas via COM port...). At the beginning we use Xport as a gateway to make Routis working with Delorme Earthmate because the old Earthmate USB to Serial driver doesn't work with Routis.
    - Xport2 fixed the Hibernation problem, but Xport2 doesn't work by itself. You need a helper application as well. That helper application is Compass also found at Xport2 download page. Per Curiousity the author of the program, you can use hyper terminal (not exactly) as a helper application instead of Compass.
    The idea behide replicating comport is that you can run 2 or more GPS applications at the same time without having to by 1 GPS for each application. In my case, I want D3 feature especially in Advance mode and Routis for Voice Navigation and Routing, Street Atlass for POI, Compass for little compass spinning around ... ...
  1. anyone using FIR port on EPIA M board?
    By stimps in forum Input Devices
    Last Post: 04-25-2009, 09:29 AM
  2. serial port to game port adapter wiring
    By asif in forum General Hardware Discussion
    Last Post: 08-17-2006, 04:47 PM
  3. Com port service/app for digital IO
    By momanz in forum Software & Software Development
    Last Post: 12-03-2004, 01:57 PM
  4. USB Serial Port Adapter Troubles
    By bLindmOnkey in forum General MP3Car Discussion
    Last Post: 10-13-2004, 11:29 PM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 08:48 PM
