That will help cause if it says exit left instead of turn left then i would look at the screen
Thanks this should be good![]()
Well it'll say "Exit to the left" rather than "Left turn" so maybe that will help?
Destinator 3 For PC! - http://www.map-monkey.co.uk/
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Where can I dowload the newer UK map?Originally Posted by wizz
I too experinace the above bug (Only bug really)...and would like to sort it out
vintageb3
So does this mean, with a Bluetooth audio gateway installed (and appearing as a sound card), you could have your Frodo/Mediacar/centrafuse music/radio playing through the car speakers, and gps directions playing through a bluetooth headset, so that the rest of your passengers aren't annoyed by SatNav voices piping up in the middle of songs? Kind of cool really.
4x4 in a turbo stylee.
Yes you can SkraggyOriginally Posted by Skraggy_uk
This is why im having speakers in the headrest so i hear the directions and only the passengers hear music or movies
As long as the BT headseat is shown as a soundcard in windows then you can use this as the main audio for navigation![]()
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Well you can easily make a small program to stop voice directions (mute them) when you pick-up a callOriginally Posted by Skraggy_uk
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
Since we are discussing sending different audio sources to different outputs I am wondering if anyone has thought about a way to use the 3 different sound jacks on the Mini-ITX boards for this.
With SMARTSound they are 5.1 speakers (front/back/sub). Does anyone know of a utility or similar that could "map" different audio sources to different channels, e.g. Movie sound to "back" channels, MP3 sound to "front" channels and Destinator to "sub" channels?
I think this would be really great. Especially since there would be no need for additional hardware in an already limited space.
Any suggestions?
BrightHead![]()
My Destinator maps say 'take 1st exit' or something similar for a left turn.Originally Posted by NiN^_^NiN
I just drove from Sydney to Adelaide, which involved goign through Victoria, and it was the same there, so I imagine that it's going to be the same in Melbin.
C!
http://carpc.riposte.net
I reserve all rights in connection to each post I author, without exception.
You still have the problem with programs needed to select which channel to use so its not a solution any better than a seperate soundcard.Originally Posted by BrightHead
Yah it would be the sameOriginally Posted by C4M
I hope the GPS got you there without a hitch?
CarPC Status:
GPS: 99%
Hardware: 99%
Software: 92%
Case Install: 99.9%
Dash Install: 100%
Car Install: 72%
