Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Destinator 3 Audio Plugin (1.1.2 and above)
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Exclamation Destinator 3 Audio Plugin (1.1.2 and above)
    Destinator 3 1.1.2+ Audio Plugin
    Have sound alerts on any sound card!
    Initially requested by NiN^_^NiN, I created this really just to show you what sort of stuff can be accomplished by using the winsock connection.
    Basically, this app will sit in the system tray and automatically connect to the frontend when it becomes available. When you are approaching a maneuever, the app will output the directions to the chosen sound card. (AS WELL as destinator, so you'll need to disable them)
    You can set it all up (sound card, where it finds the sound files etc.) by right clicking on the icon in the tray and selecting "Settings"
    I must note that the SDK only seems to tell you whether you'll be going left, right or straight on at a roundabout, so I couldn't tell which exit it would be...seems to work well enough however.
    Download
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Aug 2003
    Warrington, UK
    Almost forgot, to use this you'll have to enable Plugins by opening up your Settings.ini and changing Enabled=No to Enabled=Yes under the [Connection] category.
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by Ninja Monkey
    Is this why I was only getting these basic directions for roundabouts on Destinator embedded in Mediacar, or are you just refering to the SDK only ?
    Wizz
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
    Aug 2003
    Warrington, UK
    This is something different - What you're getting is because of a bug in the maps. I was having the same problem with the maps from the old pocketPC CD. The mio maps and the new 2004 maps work fine with roundabouts.
    Nov 2004
    Leicestershire UK
    Thank you NM. I have change to a newer UK map and resolved my roundabout issue.
    Wizz
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    Iv only just got around to checking the file u sent me NM
    Does this mean it doesn't tell you to to keep left or keep right or does it only have a problem with which exit from the round about?
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    Low Bitrate Wolfman's Avatar
    Nov 2003
    East Texas
    so if i read this correctly.....i can install 2 sound cards and a seperate speaker just for the voice directions in destinato?
    Aug 2004
    Wolfman: Yes what iv got in the car is USB soundcard which this pludin sends the voice directions through.
    Thanks to Scouse Monkey idea im having some speakers installed int he head rest so i have voice directions telling me where to go while the main car speakers are used for mp3
    Also cause i have Dual LCD i turn the radio on (i have a FM modulator for carpc sound) and the back seat people can play games watch movies or whatever while i listen to the radio and have the voice directions in the headrest teling me what to do.
    Reason iv got this done this was is in Australia if a movie or game is in view of the driver its illegal but sound from a movie is illegal so the back seat passengers have to wear headphones.
    This is why i can put the radio on while other people listen or play games using the 2 snes controllers in the back while i can still listen to the radio and get directions by visual on my screen in the front while getting audio directions
    Only thing i want to know is does htis plugin tell me everything like stay left turn right turn left in 200 500m etc.
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    Aug 2003
    Warrington, UK
    It will tell you everything destinator does (I used the same 200 and 500 meter distances) apart from which exit on a roundabout to use (you will only hear left turn or right turn).
    But I imagine the visual notification will tell you which exit?
    Aug 2004
    Ahh so it will say left turn at the round about instead of take 2nd exit.
    Well thats good enough for me altho it be nice if it said roundabout turn left so i know to look at the screen for which exit to use but thats not bad
    Thanks NinjaMonkey i'll have to get this all installed hopefully soon for the aussie car meet
    Thanks for the plug-in tho if you need any help with anything just ask no matter how mundane
    Now if you excuse me im just gonna stare at this for 20mins or so sweet lmao
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
