Results 1 to 10 of 12
Thread: Delorme USB with D3
    Maximum Bitrate djXternal's Avatar
    Jul 2004
    Tampa, FL
    Delorme USB with D3
    I have searched and searched and wasnt able to find instructions on how to get the usb Delorme Earthmate to work with D3... maybe i just overlooked it, but i couldnt find it
    any help would be great
    Debating on installing a carpc in my Jeep.....
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Do you know if this uses NMEA or SiRF? Or is it some other protocol? (Like garmin)
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Jul 2004
    Tampa, FL
    says....
    NMEA-compliant, 12-channel receiver
    SiRFstarlle/LP low-power GPS chip set
    so not really sure which one
    Aug 2003
    Warrington, UK
    You probably need to find out which one it's using...it won't be both at the same time
    What error message does D3 give you?
    Jul 2004
    Tampa, FL
    no error... just cant find the gps
    Aug 2003
    Warrington, UK
    Even if you enable advanced mode, select the COM port and put the baud rate on autodetect?
    Jul 2004
    Tampa, FL
    hmmmm and how do i enable advanced mode?
    Nov 2004
    Seal Beach, CA
    You probably need to re-install the Earthmate drivers also. When you install, it asks if you are going to use the Earthmate with Delorme software only, or 3rd party software. If you select the first option, I'm pretty sure the Earthmate won't show up on a COM port. If you do the 2nd option, it install the USB-to-COM drivers.
    - O
    2004 Toyota 4Runner Sport 4WD
    Opus 90W, Epia M210K, Lilli 7" TS, 30GB, CDR/DVD Slot, PowerMate, Earthmate, 200GB Seagate 3.5", Verizon BroadbandAccess, CentraFuse, Valetine1 .....
    Jul 2004
    Tampa, FL
    alright looks like the problem was the drivers... thanks for the help, and Ninja Monkey, incase u ever need to kno in the future... the delorme is NMEA
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Go to GPS forum and search for Delorme Earthmate and Routis. You will find out which driver will work and how to install it. The latest driver will works with all apps.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. iGuidance with Delorme USB Receiver
    By muldrick in forum GPS
    Last Post: 12-12-2004, 08:30 PM
  3. D3 with USB GPS after HIBERNATION
    By BOND007BE in forum Map Monkey
    Last Post: 11-26-2004, 02:54 PM
  4. FS: Delorme USB GPS
    By xizor in forum Classified Archive
    Last Post: 10-07-2004, 01:33 PM
  5. Replies: 12
    Last Post: 09-06-2004, 07:34 PM
