Results 1 to 10 of 10
Thread: Speed Reading
    Speed Reading
    Is there any way I can change this from reading in kph to mph as i'm in the UK and its very hard to understand, lol
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Click on Menu->Setting->General Setting.
    You can now select Imperial system (MPH) or Metric system (km/h) under Units System.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    FLAC Chairboy's Avatar
    Jan 2004
    Can I convert it to display hogshead per furlong?
    Chrysler 300 - Fabricating
    http://hallert.net/
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Not yet, but I'll be sure to add it to my list
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    NM
    While we are on the subject of speed reading. I have noticed that the large speed reading displayed on the map page is aprox. 5mph slower than my car speedo reading. As this appears to be pretty linear once on the move, is there a way that an adjusment can be added so that both figures can match ?
    Wizz
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
    Jan 2004
    The GPS speed reading, while lagged a second or two, is almost definately more accurate then the speedometer in your car.
    http://hallert.net/
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    What Chairboy said
    •Micke
    Aug 2003
    Warrington, UK
    I stuck the speedo update in with the ETA/ETR, Satellite count and Camera Detection which is set to refresh every 2 seconds.
    I'll make a change to refresh the speedo whenever GPS data comes in, that should make it a little more accurate but it will still be around a second behind...even so, I would never want to sync it with my real speedo
    Jan 2004
    Something that might be an interesting experiment, if you have an OBD-II reader, most cars report their speed via the interface. It might be interesting to see what THAT reports to see if the problem exists in the car circuits or the physical speedo gauge.
    You might consider setting the cruise control at a few common speeds and noting what the GPS indicates. Then you'll have an idea what your true speed is, might be helpful when the long arm of Johnny Law is nearby.
    http://hallert.net/
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by Ninja Monkey
    Thanks, NM
    That sounds like it could be very helpful.
    Wizz
  1. UK speed limit database available?
    By chunkymonkey909 in forum GPS
    Last Post: 04-18-2009, 07:57 PM
  2. Via Epia M PCI Bus Speed?
    By Nico3k in forum General Hardware Discussion
    Last Post: 09-23-2004, 06:05 PM
  3. Speed camera detection software on laptop
    By rickyaswell in forum LCD/Display
    Last Post: 08-26-2004, 07:13 AM
  4. Distance, Speed Logging Utility?
    By Bigtom2000 in forum GPS
    Last Post: 06-18-2004, 05:42 PM
  5. Replies: 3
    Last Post: 06-04-2004, 10:43 AM
