Results 1 to 10 of 14
Thread: SiRF!
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    SiRF!
    Just thought I'd let you in on the latest frontend development
    Limited SiRF support is now up and running for beta 3!
    I say limited because I've only been able to test it with my BU-303. But it's true, the update frequency is much quicker
    I'll keep you posted on a release date
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Nov 2004
    What is sirf?
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by Ninja Monkey
    I also use a BU-303 and was using SiRF on 1.1.2. the update was quicker, but I found that the accuracy didn't seem as good as NMEA. The trace seemed to move about on the screen more, even when stationary, and for any known reference point NMEA seemed nearer the mark.
    Perhaps it was jut me ! anyone else find that ?
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
    Maximum Bitrate yunusyu's Avatar
    May 2004
    Hollywood
    YES YES YES YES YES YES!!!!!
    11500 speed! f the 4800!
    You da man NM....cant wait till we all launch...i will keep in touch
    DICE Los Angeles
    Jan 2004
    NYC
    Quote Originally Posted by Lord_Pall
    What is sirf?
    I would like to know too, would this work with the earthmate USB
    Nov 2004
    NY tri-state
    Quote Originally Posted by camsgs3
    It's tricky because SiRF itself is actually the company that developed the chipset that ended up in a lot of GPS receivers -- including the Delorme, which IIRC is powered by a SiRF SstarIIe. SiRF also refers to the protocol though. Most newer receivers out there support both SiRF Binary and NMEA outputs, it's only a matter of what the software that you're using supports.
    It would only make sense that the fine folks at sirf.com would have something to clear up what SiRF exactly is, but alas I don't think that's the case...
    Aug 2003
    Warrington, UK
    For the earthmate see this thread Delorme USB with D3
    Aug 2004
    Ninja Monkey you are an absolute star!!!!! This sounds amazing!!!!!
    Constant Bitrate naveedh's Avatar
    Oct 2004
    so is this basically moving as fast as the car goes in a smooth line in 3d mode? because iv never experianced sirf!
    Aug 2003
    Warrington, UK
    No, you'll never get faster than 1Hz updates with the current SiRF recievers, but that's still faster and more accurate than most NMEA devices.
  1. Sirf Supported Or Not?
    By baller in forum Map Monkey
    Last Post: 12-03-2004, 11:23 AM
  2. Replies: 11
    Last Post: 12-02-2004, 02:12 PM
  3. SIRF anyone?
    By grahamrb in forum Map Monkey
    Last Post: 11-21-2004, 05:59 PM
  4. BU-303 and SIrf
    By matty_g in forum GPS
    Last Post: 11-15-2004, 01:18 PM
  5. anyone using SIRF mode?
    By PTCruiser in forum GPS
    Last Post: 03-04-2004, 11:30 AM
