Results 1 to 9 of 9
Thread: Changing Turning Length?
    Constant Bitrate naveedh's Avatar
    Oct 2004
    Does anybody know how to do this, i mean like when i approach a turn it says "turn left 500yards" Now 500yards is a long distance i want it like to alert me 200 yards before. How can i do this? Btw i am using CDrSkull's voice pack.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    when i'm using the default voices, it gives me a warning at 500yards then 200yards then again at the turn.
    肚子笑痛了
    S60 Install
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Pretty sure you can just rename your 500.wav and it'll ignore it (The audio at least, you'll most likely still get visual notification)
    or if that doesn't work, open your DestinatorVoiceManeuvers.inf inside the voice folder and comment out (//) any lines that mention the "SECOND_DISTANCE" command
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by Ninja Monkey
    Thanks for that. Commenting Out works a treat. There is still a visual alert on my setup at 500yds but no voice until 200yds which is absolutely ideal for me.
    Thanks again,
    Wizz
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
    Nov 2004
    France
    You can also edit "DestinatorVoiceManeuvers.inf" (in the voice you choose to use)
    You can modify all distances and messages.
    Be careful, make a backup !
    Newbie mick-uk's Avatar
    Dec 2004
    Angry
    can all refrences to 500yards be removed from DestinatorVoiceManeuvers.inf?
    I want to get rid of both the message and the display.
    Dec 2004
    Quote Originally Posted by mick-uk
    or even better, would it be possible to change the warning for 500 yards to 300, and 200 yards to 150yards?
    I want to have ago at editing the file but i dont want to mess things up
    Code:
    ::MC,KEEP_LEFT*SECOND_DISTANCE,0,0,k_l;500;UNITS,"Keep left five hundred yards/meters"
    does the "500;UNITS" define when the call the file up?
    Aug 2003
    Warrington, UK
    No, that defines the name of the WAV file to play (500.wav)
    the "SECOND_DISTANCE" variable will be defined as 500 somewhere else
    Edit: And from the looks of it, not in that file
    FLAC Chairboy's Avatar
    Jan 2004
    Another way, try to sneak up on the turns. If you come towards the intersection, then, about 600 yards away, make a 45 degree turn and start crabbing across the street, the computer might think you're going somewhere else and start recalculating the route. Then, the moment it isn't looking, you wrench the steering wheel back and hit the throttle.
    As you bounce over the sidewalks and dodge oncoming traffic, your computer will realize its mistake and try to tell you that your turn is 500 yards ahead, but by this time you'll be close enough to the turn that it'll give you the closer warning.
    One problem with this method, there seems to be an odd statistical correlation between traffic collisions and doing this. I think that's probably a fluke, but that and severe undercarriage damage seem to show up a lot, so, your mileage may vary.
    Good luck!
    Chrysler 300 - Fabricating
    http://hallert.net/
  1. Replies: 4
    Last Post: 07-03-2006, 09:45 AM
  2. Custom length IDE cable (HD, CD/DVD, Floppy)
    By jtk in forum Classified Archive
    Last Post: 03-23-2005, 03:45 PM
  3. Lillput- Fussy about VGA cable length?
    By live2themaxuk in forum LCD/Display
    Last Post: 08-22-2004, 08:03 AM
  4. Replies: 10
    Last Post: 08-12-2004, 04:45 PM
  5. Program to cut the length of mp3 files???
    By zzsprade in forum Software & Software Development
    Last Post: 08-04-2002, 04:40 PM
