Thanks again NM - worked this time. Is there any way to use a keyboard key to jump between selecting city - street and then show or do these have to be clicked with the mouse? The mouse on the Libretto isn't that easy to use!
try SPACE
You can't use shift because that's a modifier - you would only be able to use it in combination with another key
Destinator 3 For PC! - http://www.map-monkey.co.uk/
There sure is...
FE_CYCLE_DIALOG_FWD
and
FE_CYCLE_DIALOG_BCK
to cycle through City/Street etc..
Show would be
FE_CLICK_BUTTON_2
Thanks again NM - worked as usual.
Dragging DOES work but you need to be in "Planning" mode not "Navigation".
Being in "Navigation" mode will keep resetting the map to your current position.
Dragging works in both modes here.
NM - Is there a hotkey I can set to set the origin until I get a pcmcia gps card to use with destinator?
Hello!
..one more question:
Is there any chance to hookup the "+" and "-" key (need it for Zoom) in the hotkeys.ini?
I've tried "+", "ADD" or "PLUS" with nu success.. ;-(
Big Thx in advance!
