Results 1 to 10 of 17
Thread: Scrolling the map
    Dec 2004
    Scrolling the map
    Is there any way to scroll along the map, either up/down/left/right as required? I know you can set the hot keys but they don't seem to work for some reason.
    Oct 2004
    East Sussex, England
    Drag it! Or do you not want to do that?!
    Dec 2004
    Dragging it doesnt work... it just moves the wee section currently displayed and then puts it back if you know what I mean.
    I'd like to be able to scroll using the keyboard because the mouse on the Libretto laptop isn't easy to use.
    Dec 2004
    Dragging actually does work on the Libretto - but is there a way to make the UP/DOWN/LEFT/RIGHT keys do it?
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Setting the Hotkeys will do it
    Post the lines in your Hotkeys.ini that didn't work
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Dec 2004
    Hotkey43=Local,FE_SCROLLMAP_UP,{CTRL},UP-1
    Hotkey44=Local,FE_SCROLLMAP_DOWN,{CTRL},DOWN-1
    Hotkey45=Local,FE_SCROLLMAP_LEFT,{CTRL},LEFT-1
    Hotkey46=Local,FE_SCROLLMAP_RIGHT,{CTRL},RIGHT-1
    That's the lines from the hotkeys file. I wasn't really sure if the -1 had to stay or not...
    I wanted to be able to use the UP/DOWN/RIGHT/LEFT keys to scroll the map.
    Aug 2003
    Warrington, UK
    Quote Originally Posted by bryan
    The -1 shouldn't be there. But then even without that you are setting it to be CTRL+UP, CTRL+DOWN etc...
    try this instead
    Hotkey43=Local,FE_SCROLLMAP_UP,,UP
    Hotkey44=Local,FE_SCROLLMAP_DOWN,,DOWN
    Hotkey45=Local,FE_SCROLLMAP_LEFT,,LEFT
    Hotkey46=Local,FE_SCROLLMAP_RIGHT,,RIGHT
    Dec 2004
    Cheers NM - that worked.
    What line in the hotkeys.ini do I need to modify to bring up the streetfinder window?
    Thanks,
    Bryan.
    Aug 2003
    Warrington, UK
    Fe_menu_item_routeto_address
    Dec 2004
    I've tried setting that line to SPACEBAR or SHIFT but neither of these keys seem to work - are these not allowed?
  1. Add More Roads to a destinator Map?
    By bns2000 in forum Map Monkey
    Last Post: 01-21-2008, 12:03 PM
  2. Delorme Street Atlas 05 quick review
    By cash_Money in forum GPS
    Last Post: 12-13-2004, 08:31 PM
  3. Crashing Map
    By RoyN in forum Map Monkey
    Last Post: 11-20-2004, 12:30 AM
  4. Replies: 4
    Last Post: 02-26-2004, 10:52 AM
