I keep trying to press the STFU button.Originally Posted by johnwharrison
Sorry if this has been answered before, but I couldn't find it. I am going on a cross country trip (in US), so my question is: can I load the entire north america map to plan the trip or do I need to plan the trip segment by segment according to the destinator sections?
Thanks a bunch!
Nice one... been very busy and only just seen this... thought SiRF support was not going to be in this beta.
Working on the release time basis - I guess the next one will be the finnal... some time in March ?
Terran
SORRY No you can't load the entire map, remember it was designed for the PDA and it's memory restrictions.Originally Posted by rainman1
When the UK was in a number of segments there was a main route skeleton of roads on each segment and you could plan a final destination and then swap maps when you reached each ones border. I don't know if that would apply to the USA.
We have a major routes of europe map where a european international journey can be planned, but I don't think a similar map is available for USA, at least I have never seen one.
Wizz
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
1. Have you even looked in destinators own settings?Originally Posted by Enforcer
2. SiRF or NMEA?
3 & 4 I'll look into
5. I can't control mediacar
Destinator 3 For PC! - http://www.map-monkey.co.uk/
That's a bit bizzare, Mediacar can't have changed either! Maybe your sending a back/esc keystroke when d3fe is closing or something?Originally Posted by Ninja Monkey
Mine has always done this?Originally Posted by Enforcer
SB
"The gene pool could use a little chlorine..."
Originally Posted by wizz
http://www.buygpsnow.com/item.aspx?itemid=285
note: I've never installed this major roads stuff, so I'm not sure if it works, and I'm not sure if it's cheaper somewhere else. If it is, PM me!!!![]()
now does destinator use the pocket pc or palm systems, or windows? i know this frontend is for windows, but if i want to buy the maps, do i need the pocket pc maps? and if i use the pocket pc ones, i need to load new maps every once in a while to keep the trip going? will destinator use existing maps? i have delorme street atlas, and i'm assuming it won't use the map files in there, i need destinator, right? and if i need destinator, and they make one for windows, not just the pda files, where is the best place to buy it from. i want to try this frontend, it looks EXACTLY like what i'm looking for, 3d viewing, turn by turn directions, rerouting for avoiding routes, whammo.
1.Originally Posted by Enforcer
Destinators startup defaults have been changed.![]()
2. NMEA
5. Not expecting you too, just mediacar has not changed but the behaviour has since the new beta came out. Will doublecheck this to make sure I'm not seeing things
As said before, nice work ninja.
