nice!! going to take this down to the car now, I love the idea of it telling you what road to turn on.
TESTING OF 1.1.3 IS NOW OVER
Download updated 16th Jan to include Hotfix #1, #2 and #3
Now this version is the first to offer full support for plugins! The SDK is so easy to use I created 4 to include in the standard installation!Code:Version History [v1.1.3.29 BETA3 Hotfix 3] -Added ability to import PocketGPS databases -Added ability to export speed camera databases to CSV -Fixed issues with Centrafuse closing the frontend -Fixed overflow errors with speed camera alerts [v1.1.3.26 BETA3 Hotfix 2] -Added ability to set volume for voice directions -Non-English regional settings should now be supported [v1.1.3.23 BETA 3] *New Features* -------------- -Destinator Frontend SDK (D3Talk) The SDK for the frontend has been released. This makes it very easy to create your own plugins or embed and integrate the frontend fully in your application. -Plugin Structure The frontend now allows you to select the plugins to use at startup. -SiRF Support in Advanced Mode It is now possible to recieve higher quality updates via the SiRF protocol. This has not been fully tested. -Windows Media Player Control You can now map your Prev/Play/Next buttons to Windows Media Player. -QuickFavorite A button on your skin or a hotkey can now be assigned to quickly add the current location into a favorites folder. Only the "Classic" skin has this button by default. -Default Address Sort View You can now specify the default view to use on the route to address dialog -Background image on skin By placing a "Tile.JPG" inside your skin folder, the image will be tiled on your skins background rather than a colour. -Hide Mouse It is now possible to allow Destinator to hide your mouse while it's running (and make it visible again upon exiting) -Remove Speed Camera When a speed camera warning appears, a button also appears next to the "Add Speed Camera" button allowing you to delete the camera from the database -Route Home A new destinate option has been added called "Go Home". This allows you to quickly route to some preset coordinates. *Changes / Fixes* ----------------- -Speed Camera Databases The speed camera detection now uses full databases to store and retrieve data. This should greatly improve speed of operation and work independent of the users language settings. -Border around speed As well as a shadow effect, it is also possible to simply have a coloured border around the on-screen speed display -Clicking Satellite Image Clicking the satellite image next to the satellite count will now open GPS Status -ETA/ETR Estimated Times Remaining/Arriving have had a complete overhaul. They are now determined on the fly using your current speed. If you are not using Advanced mode they are calculated using a customisable preset speed. -Scroll Speed in Dialogs The scrolling speed of the scroll buttons when in dialogs has been greatly reduced -Zoom Steps You can now customise the amount of steps between each zoom (for the skinnable zoom buttons and zoom hotkeys) -Hotkeys for scroll buttons Hotkeys have been added for scrolling dialogs -Other Bugs/Fixes Many other undocumented or trivial bugs have been resolved.
Daily Logs
This plugin, when activated, will keep a categorised-by-day history of your entire journeys including total distance travelled, speed, road name etc.. Look back at any point in time and see exactly where you were!
External Audio
Have alerts for upcoming maneuvers played on a different sound card
SAPI Plugin
Prefer a customisable computerised voice for voice directions? Well here you go! This plugin can even speak the name of the road you need to be turning into as well as the added option of announcing whenever you enter a new area (city / zipcode etc)
Location Trigger
An advanced database-driven plugin that lets you perform actions based on your current whereabouts. You can specifiy the sensitivity, required max/min distances, speeds, bearing. Once set you can specifiy either a sound file to play or even run an application passing your coordinates as parameters.
An extra feature of this plugin allows you to set up a keyboard shortcut to automatically add an item to the database based on your current location and then automatically begin recording the sound file to play!
Download Here [15.1MB]
Find me some bugs!
Destinator 3 For PC! - http://www.map-monkey.co.uk/
肚子笑痛了
S60 Install
can;t wait to test it...
Awesome to see the SDK finally come out. Can't wait to play around with it
I guess I really should start saving for the rest of my system![]()
Progress: On hold while I pay off my new PowerBook :D
Part List:
VIA MII10000 - 512MB - 20Gig 2.5" - Rikaline 6010 - 7" Lilliput - CNX-P1260 - Alpine 4ch Amp - 4 Gauge wire and fused distrobution block.
Magic. Thanks a billion..............![]()
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
Still getting the message that Font tahoma not found, and then it craches, i tried it on 4 computers and the same problem. but i got the tahoma
Can it be my regional settings? -danish-
Nice work Ninja, will start testing this out tonight...
John
My Nissan 200SX @ Silverstone
NOW SADLY WRITTEN OFF!
My Car's spec list + pics
Stealth CarPC fab'ing...
Nice work NM - was just thinking about the daily logs function myself - I work as a Systems Engineer travelling around - could be perfect for doing my travel expenses :-)
Great work!
Can't wait to try this new version. Gonna install it and try it on my trip home.
Lilliput 7" TS / VIA EPIA M10000 / 256 MB DDR RAM / 40 GB 2,5" Toshiba HDD / TEAC DVD Slimline / GlobalSat GPS USB
Yeah!! this is what i was waiting for... thank NM!!!! i love you
my destinator map resource down permanently
