Page 2 of 15 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 142
Thread: 1.1.3 BETA(3) - Bug Reports
  1. #11
    Constant Bitrate skydiver's Avatar
    Nov 2004
    southampton (UK)
    ok fixed it coped file mscomctl.ocx from my xp system and registederd it and all is fine now.
    How
    copy both files "mscomm32.ocx" & "mscomctl.ocx" to the system32 folder of your system
    To regester on XP run
    C:\WINDOWS\SYSTEM32\REGSVR32.EXE C:\WINDOWS\SYSTEM32\MSCOMM32.OCX
    and on WIN2K run
    C:\WINNT\SYSTEM32\REGSVR32.EXE C:\WINNT\SYSTEM32\MSCOMM32.OCX
    Do the same for both files changing only the last bit
    hope it helps
    Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
    The car
  2. #12
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by viguera
    I used the software for a good hour today, and the only things that I've found are:
    * Switching to sirf mode just gives me a "GPS not found" -- I'm fairly sure that my receiver supports it, but I'll double check.
    * Using the SAPI plug-in produces double-speak (one in each voice). Disabling voice notification and leaving visual notifications only doesn't work... you still get double voices. I had to leave it at no notifications to stop hearing the D3 voice.
    The other issue that I had of not been able to disable the speed cameras just went away... not sure what I did or didn't do.
    You can't just switch to sirf mode, you need to re-configure your GPS into sirf first!
  3. #13
    Apr 2003
    milan, mars
    maybe using sirfdemo.exe, may i add
  4. #14
    Variable Bitrate ildena's Avatar
    Dec 2004
    Italy
    Lot of error messages using red cams alert.
    I'm using italian database on new 2004 italian maps
  5. #15
    Aug 2004
    Denmark
    I did try sirf mode, but a voice says: not enough sats. It so unstabil. And in NMEA it also connect faster. Only have bad experience with Sirf Dont know were the probs are...in D3 or in my gps reciver..
    P4.1,8 - 512 ram - Power: M1-ATX 6-24V DC/DC - HU: Blaupunkt Seattle MP74 - Lcd: lilliput touch. - GPS rec. Navilock NL-202U ( USB).- 2 usb for ex. - 1 cardread. 9 in 1. - Softw.: MapMonkey - Frontend: Roadrunner
  6. #16
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    "Lots of errors"?
    come on guys, that really doesn't help
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  7. #17
    FLAC mauri's Avatar
    Jan 2004
    Tested in my car.
    Situation:
    Car firm, displayed ok speed (0 values KMH).
    I number satellites in receipt OK (10)
    The whole rest ok.
    Car in movement:
    immediately displayed error:
    Number: -2147217900
    Description: Error of syntax (virgola) in the expression of the query 'val(longitude) 12.4706366667
    AND val(longitude) 12.4046366667 AND val(latitude) 4419105 AND val(latitude) 4412505.
    Source: Check_For_Camera
    Version: 1.1.314
    HelpContext: 5003000
    HelpFile:
    LastDllError: 0
    D3 and jammed in the functions of all the buttons, but the speed, the receipt of the satellites, and also the current position and displayed correctly
    on the map ( Italy version 2004).
    The file FE_speed cams i have put correctly in " Favourites ".
    Tested in stand-alone mode e embedded to Mediacar.
    EDIT: Import utility random don't work, doesn't turn the database file of the speeds cams into " Favourites" .
    Mauri
  8. #18
    Constant Bitrate naveedh's Avatar
    Oct 2004
    ok this isnt a error, but do you have to have the www.mp3car.com link flashing all the time? please dont take it in the wrong way.
  9. #19
    Aug 2003
    Warrington, UK
    yes i do.
    you're supposed to be simply testing it for me, not using it as your main GPS application
  10. #20
    Aug 2004
    I don't want to offend anyone!!! But Ninja monkey, how do you put up with the constant repitition of the same questions?????
    BTW thanks for the SIRF support its spot on!!!!
  1. Bug Tracking (sorry long but please read)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-22-2005, 03:12 PM
  2. 1.1.3 BETA(2) - Bug Reports
    By Ninja Monkey in forum Map Monkey
    Last Post: 01-02-2005, 07:35 PM
  3. 1.1.3 BETA - Bug Reports
    Last Post: 11-29-2004, 03:48 PM
  4. Bug Reports 1.09
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-22-2004, 10:24 PM
  5. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 04:32 PM
