i posted this in the other thread..
it wont load when i click the gps button in frodoplayer?
EDIT: Just fixed the so called bug.. i had to add the \Frontend_BETA3\ folder to the location in the frodoplayer.ini file.
Bugs here!
Keep discussion to a minimum please
Edit: Can people with errors do the following:
open your Settings.ini and change or add (if it's not there) the line Debug=On under the [Global] header. You will then find a Debug.log file everytime you run the frontend. Post this as an attachment with your bug report.
Destinator 3 For PC! - http://www.map-monkey.co.uk/
mscomm32.ocx error, google it, copy and paste in windows/system32 directory.
I am getting the same error on a new install of win2k tryed the copying and pasting bit but still no joy .It works fine on my xp home pc instantly .Am i missing something has anythink else got to be installed for it to work (VB or somthing)
thanks![]()
Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall returnThe car
yuou have to register it tooOriginally Posted by skydiver
my destinator map resource down permanently
Little issues.
1. CPU Useage 100% when in configuration screen. (Only relised because my lappy started to get VERY hot.)
2. Sometimes pressing the X in top right to close Destinator, dusn't fully unload the application, causing lots of errors when restarted... ie "application already loaded" etc.
3. I dont have another bug,just, load speed seems slightly slower than beta2.
oh, and thanks.
mick.
Error Details:
Number: 383
Description: 'Text' property is read-only
Source: Open_Setup
Version: 1.1.323 BETA3
HelpContext: 1000383
HelpFile:
LastDllError: 0
I started having this error after that I imported the red cam db.
The configuration utlity must to be reconfigured anytime you run ut because all the fields are white...
I answer to myself...
If you don't want this error don't touch the % value of the volume of winamp when there's a destinator messagge
I used the software for a good hour today, and the only things that I've found are:
* Switching to sirf mode just gives me a "GPS not found" -- I'm fairly sure that my receiver supports it, but I'll double check.
* Using the SAPI plug-in produces double-speak (one in each voice). Disabling voice notification and leaving visual notifications only doesn't work... you still get double voices. I had to leave it at no notifications to stop hearing the D3 voice.
The other issue that I had of not been able to disable the speed cameras just went away... not sure what I did or didn't do.![]()
In the top left hand corner, there is alittle image of a satalite, with a number next to it, in beta 2 this number used to change, 6 7 9 etc, so i thought it was disaplaying the current number of satalites I was connected to.
in beta3, this number is fixxed at 12, even of there isnt a connection... is this a bug or are these numbers relating to something else? and not the number of sats?
After regesting mscomm32.ocx i get the same error but with the mscomctl.ocx file. i am deffenatly missing something here.
HELP!!!!![]()
