Results 1 to 10 of 13
Thread: how do I alter the voice nav volume
    Oct 2003
    just had a quick look round and it seems the answer is to use 2 soundcards, is this still the case with the latest version?
    Voice navigation at 150dB is fair loud, scared the living s**t out of me.
    Cheers
    if you can't find time to do it right, when are you gonna find time to do it over.
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by sygad
    Cheers
    Quote Originally Posted by KapMan
    Is there any way to alter Destinator's volume output?
    I usually have winamp playing at about 65%, causing Destinator to SCREAM directions at me through my car's audio set up!
    Refer to my post:-
    How can I Adjust D3/MP3 volume
    I used a figure of 28% on the UK Speech files and achieved highly satisfactory results.
    Wizz
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
    Quote Originally Posted by wizz
    Refer to my post:-
    Wizz
    This post doesn't seem to offer any information
    FLAC mauri's Avatar
    Jan 2004
    Refer to my post:-
    Wizz
    Download the Mp3gain sw, v.1.2.5 , but don't possible modified the volume of wav file in D3, format not recognize ....
    You use version?....
    Mauri
    Nov 2004
    Leicestershire UK
    Sorry Guys The strain of waiting for NM's BETA3 must have got to me
    I used MP3Gain to equalise my mp3 collection ONLY....
    I used Sound Editor from Roxio Easy CD Creator to reduce the voice pack WAV files volume & YES I didn't dream this, the magic figure was 28% of the original WAV volume on the slide control of this program.
    Please don't lynch me....I'll make it up to you in future posts...promise !
    Wizz
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    So wait, how about a feature to lower the volume just before giving speech instructions and then set it back afterwards?
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by Ninja Monkey
    The only problem there is that the WAV files vary in length.
    In the same vane, but the other way round. I've been experimenting with the winamp audio mute settings in DestinatorConfig and have found that by setting the volume to 50% and duration to 4secs, along with the reduced volume speech files and a 50% main volume setting in Mediacar, I can hear the directions clearly without loosing the jist (for want of a better word) of the mp3 playing in the background.
    Hope I've explained myself there !
    Wizz
    Oct 2003
    had opportunity to use satnav for real last night on my way to sheffield, damn that is a good bit of software.
    had to fiddle with the audio again as I forgot about the directions being blasted, this is what I found
    From the soundcard properties I had the master volume on full and the Wav volume on about 30%
    I went into winamp and turned the volume up full.
    I went into destinator config and turned off anynthing to do with it adjusting the volume.
    This way I could listen to my music at a volume I wanted and have the satnav voice over it, if i wanted the satnav louder I adjusted the WAV volume from soundcard properties and adjusted the master volume and winamp volume to get the audio right.
    Whilst this is a solution I would have preferred to have the WAV and Master volume on full, this way I am maximising the output of the card, then to have the applications control how much of that volume I wanted to hear, ie winamp controls the music and destinator controls the directions volume.
    Is this already possible and i'm just doing something wrong?
    Cheers for the replies byt the way
    Vik
    Vik is offline
    Newbie Vik's Avatar
    Nov 2004
    Belgium
    Call Me stupid,...
    But is it that difficult to include a volume control button in D3 to just alter the volume of the navigation Voice. so that I can mute or blast my ears out whenever I want.
    Oct 2003
    Quote Originally Posted by Vik
    Call Me stupid,...
    Why didn't I just say that as simply as that....
  1. Replies: 21
    Last Post: 03-07-2006, 10:43 PM
  2. How to change voice volume within Frodoplayer?
    By vintageb3 in forum FrodoPlayer
    Last Post: 01-13-2005, 11:44 AM
  3. Voice Volume Level and "Voice"
    By dug1967 in forum FrodoPlayer
    Last Post: 12-30-2004, 12:56 AM
  4. VOICE Nav - how NOT to run in full screen mode?
    By S4Per in forum V.O.I.C.E.S
    Last Post: 06-13-2004, 03:09 PM
  5. Volume mute on mp3's when voice nav operational
    By Pabs in forum Media Engine
    Last Post: 05-25-2004, 06:50 AM
