Results 1 to 10 of 12
Thread: 1.1.3 BETA3 Hotfix 2
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Exclamation 1.1.3 BETA3 Hotfix 2
    Let's see if we've made some progress!
    I can't seem to reproduce the "Overflow" error with speed camera detection, but I found what might have caused it.
    This fix also adds the ability to set the volume for voice directions
    Download here [526KB]
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Constant Bitrate superbowl's Avatar
    Jan 2005
    Germany
    Great job !
    Is Hotfix 1 included in Hotfix 2 or do i have to apply both patches an a fresh install ?
    - superbowl
    Jan 2005
    Germany
    Sorry,
    just realized that you removed Hotfix 1
    - Superbowl
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by Ninja Monkey
    NM Is this for everyone or just Non English ?
    Wizz
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Where is the setting to change the volume? also whenever you turn off the default voices the SAPI engine does not tell you about low GPS signal. is that correct?
    肚子笑痛了
    S60 Install
    FLAC mauri's Avatar
    Jan 2004
    Ninja, is the best!
    I try then tomorrow the new hotfix I make to know if and ok.
    Many Thanks
    Mauri
    Aug 2003
    Warrington, UK
    This patch includes the fixes from Hotfix #1
    It mainly fixes bugs with non-english users, but It's best for everyone to be on the same version, plus it adds a new feature you may want (voice volume)
    The voice volume setting is at the bottom of the "Audio Mute" tab in configuration
    Aug 2003
    Warrington, UK
    Quote Originally Posted by jcdillin
    Correct, the SAPI plugin will only alert you to upcoming maneuvers
    I can't work out from your post, but do you want to hear "Low GPS signal"?because it's still possible while still disabling the default voices
    May 2003
    Miami, FL
    bummer I like it to tell me to drive carefully
    肚子笑痛了
    S60 Install
    Aug 2003
    Warrington, UK
    ok, 1 second...what voice pack did you use?
  1. 1.1.3 BETA(3) - Bug Reports
    By Ninja Monkey in forum Map Monkey
    Last Post: 01-30-2005, 07:14 AM
  2. New Destinator Skin - download 1.1.3 beta3
    By mick-uk in forum Map Monkey
    Last Post: 01-13-2005, 05:20 AM
  3. 1.1.3 BETA3 Hotfix 1
    Last Post: 01-12-2005, 05:16 PM
  4. Replies: 11
    Last Post: 12-27-2004, 04:38 PM
  5. 1.1.3 - Latest Update
    Last Post: 11-17-2004, 05:05 AM
