Results 1 to 10 of 11
Thread: Importing Speed Cams
    Hey, Bit of a dumbarse question but here goes...
    How do you import speed cams into D3? I downloaded the latest csv but have no idea what to do with them...
    Cheers
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    You can't yet, there will be an import tool soon though
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by Ninja Monkey
    Can I suggest this is a sticky... including my self I think this is the third thred that has asked this...
    Terran
    Sorry, I cant see any speed cams on my maps therefore assumed they had to be imported.
    Aug 2003
    Warrington, UK
    I'm getting really fed up of explaining how the speed camera detection works.
    All the info about importing them to favorites, making them visible on the map, adding them as they are detected etc can be found by searching.
    Is there actually anyone who understands fully how it all works?
    I searched and read everything I could but still couldnt understand how it worked. Sorry...
    I'm not trying to be a pain in the arse, just trying to understand how to get it working.
    Aug 2003
    Warrington, UK
    As long as it's enabled and you've chosen your country from the list then that's it, it's working!
    Constant Bitrate HoSS's Avatar
    Dec 2004
    NM, I posted a while back regarding merging SC databases on beta2, i note that the format has changed for beta3.
    Can this be done now? and how?
    Aug 2003
    Warrington, UK
    Yes, just open the DCD files with access and copy the data from one to another. Just make sure the names of the cameras are unique or it'll fail
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    It should be like this:
    As you aproach a camara, It will detect it and display the camara on screen.
    The cameras will be added to the screen as they are detected.
    If you want all cameras in the screen, you just click in the import button and untick the option "Display speed cameras on map" ( the ones in the pic above ).
    Also, make sure that the check mark next to Fe_speedcams is checked.
    Edit: Corrected.
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
  1. Destinator freezing when you approach a speed camera?
    By Ninja Monkey in forum Map Monkey
    Last Post: 01-31-2005, 05:37 PM
  2. Via Epia M PCI Bus Speed?
    By Nico3k in forum General Hardware Discussion
    Last Post: 09-23-2004, 06:05 PM
  3. Speed camera detection software on laptop
    By rickyaswell in forum LCD/Display
    Last Post: 08-26-2004, 07:13 AM
  4. Distance, Speed Logging Utility?
    By Bigtom2000 in forum GPS
    Last Post: 06-18-2004, 05:42 PM
  5. Replies: 3
    Last Post: 06-04-2004, 10:43 AM
