Results 1 to 10 of 10
Thread: GPS not found after hibernation - Even with the "Reconnect" option!
    Variable Bitrate garo's Avatar
    Jan 2005
    Milan, Italy
    Hi to everyone!
    Just like in the topic, my Pharos 360 GPS (the one that comes in bundle with Streets & Trips 2005) doesn't reconnect after hibernation resume, even if I checked the proper option. Of course, I'm using the lastest beta of D3 Frontend and WinXP Mce2005 (SP2).
    Thanks in advance for your help
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Common problem. You have to reconnect it after hibernation
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Adv. GPS on/off?
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Jan 2005
    Milan, Italy
    Adv Mode on!
    Aug 2003
    Warrington, UK
    How do you usually fix it? Will closing and reopening destinator do it, or do you have to unplug/replug the USB to detect it again?
    I'll look into it, but mine reconnects fine so it's hard to test
    Jan 2005
    Milan, Italy
    It's enough to close and restart Destinator. In this way, the GPS starts to work immediately
    tnx
    Oct 2004
    Netherlands
    well when i get out of hibernation with my BU-303 it says gps not found! but its still working, it only says that line :S
    my destinator map resource down permanently
    Jan 2005
    Milan, Italy
    For me is different, it's not working! I former had a BU303, and it works perfectly (for example, I used "Route 66" and after hibernation it started to work immediately) but unfortunately the Pharos doesn't work this good
    FLAC mauri's Avatar
    Jan 2004
    I have seen that if if the GPS loses for some motive the signal with D3 that travels, then it takes enough time before correctly takes back the correct signal.
    A system would be useful that allows to restart " to warm" as the old D2 the GPS.
    Does thing think Ninja of it?
    Possible?
    Mauri
    Variable Bitrate drait's Avatar
    Dec 2004
    NorCal
    Quote Originally Posted by GReeToZ
    My Rikaline 6010 does the same thing so I just took the ...GPS not found... voice prompt out
  1. a new way of GPS
    By brownpage in forum GPS
    Last Post: 08-24-2004, 02:51 PM
  2. Mediacar V1.8.5
    By coyote in forum MediaCar
    Last Post: 02-16-2004, 01:16 PM
  3. Real GPS Software for Linux FOUND
    By Mxyzpltk in forum GPS
    Last Post: 10-11-2003, 08:58 AM
  4. Replies: 2
    Last Post: 09-25-2003, 03:30 AM
  5. Found a GPS receiver.
    By anothamp3frk in forum General Hardware Discussion
    Last Post: 07-15-2002, 04:20 PM
