Results 1 to 10 of 15
Thread: Whatīs missing???
    Feb 2004
    Whatīs missing???
    Yesterday i installed a nLited version of Xp and now i seem to have removed a bit too mutch? when i try to start destinator i get the following error messages:
    Error Details:
    Number: 429
    Description: ActiveX component can't create object
    Source: Create_Destinator
    Version: 1.1.329 BETA3
    HelpContext: 1000429
    HelpFile:
    LastDllError: 0
    Error Details:
    Number: 429
    Description: Invalid GPS Settings! (ActiveX component can't create object)
    Source: Connect_AdvGPS
    HelpFile:
    LastDllError: 0
    Error Details:
    Number: 91
    Description: Object variable or With block variable not set
    Source: Get_Address
    HelpContext: 1000091
    HelpFile:
    LastDllError: 0
    now...what the heck am i missing?? and where do i find it so i can replace it?
    really in need of help!!
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by Dj_Aleks
    Error Details:
    Number: 429
    HelpFile:
    LastDllError: 0
    Error Details:
    Number: 429
    HelpFile:
    LastDllError: 0
    Error Details:
    Number: 91
    Source: Get_Address
    HelpFile:
    LastDllError: 0
    Looks like you haven't installed D3 correctly!
    Feb 2004
    Quote Originally Posted by Laidback
    thats because i couldīn install it thanks to an error..so iīm acutally missing something already there...so i took my installed version from my desktop and put it on my carputer...anybody else have an idea? i just canīt figure it out!
    edit: but whatīs the actual error?? what would the change be when installing it?
    Oct 2004
    Netherlands
    so you copied the folder over ?? then it doesn't register stuff just run the install file on the carputer reinstall it will work
    my destinator map resource down permanently
    Feb 2004
    Quote Originally Posted by GReeToZ
    well i acutally did register the dlls and ocx files but still no luck, and as i said in the post above, if i could install it i would have done that! iīll post the error message that the installer gives and maybe i can start from there..
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    If I were you I'd install XP FULL. Looks like your missing some active X components in XP itself. If you use a reasonable power controller and hibernate feature of XP you should still get the useability and speed you want.
    Wizz
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
    Feb 2004
    Quote Originally Posted by wizz
    Wizz
    xp full is no option, itīs too big and to slow by far! is it possible to acutally install the active x components afterwards??
    Rub One Out Motoko's Avatar
    Hertfordshire, England, Earth, Solar System
    i got this error before, i registered all the OCX i could find and it resolved this error:
    Error Details:
    Number: 429
    HelpFile:
    LastDllError: 0
    but now i get this error:
    Error Details:
    Number: 429
    HelpFile:
    LastDllError: 0
    CarPC status: iPod, 3,456,217 songs so **** you
    Feb 2004
    Quote Originally Posted by Motoko
    Error Details:
    Number: 429
    HelpFile:
    LastDllError: 0
    Error Details:
    Number: 429
    HelpFile:
    LastDllError: 0
    same as me! i just donīt get it..
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    The latest installer puts all the required OCX and DLL's in the windows\system32 folder...maybe they haven't registered properly
    try copying GTXP.DLL from your system folder to your Destinator_BETA3 folder (That should fix the "Connect_AdvGPS" error)
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  1. cant change skins???
    By Hell-Stopper in forum FrodoPlayer
    Last Post: 11-05-2004, 11:10 PM
  2. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 01:25 AM
  3. Replies: 10
    Last Post: 10-12-2004, 04:43 PM
  4. Missing Sliders
    By vicky_obee in forum MediaCar
    Last Post: 07-15-2004, 01:08 AM
  5. Missing Slider
    By Pokey in forum MediaCar
    Last Post: 05-25-2004, 07:08 AM
