just tryed it and i get a sceen that is embeded saying launching destinator but another window opens with destinator in it ontop
I've written a D3 Launcher for centrafuse that will workaround the map not moving problem
I've only given it a quick test so your feedback would be appreciated.
Simply copy the EXE into your Frontend_BETA3 folder and then in centrafuse:
Point your GPS application to : C:\DestinatorApps\Frontend_BETA3\CFD3Launcher.exe
Set the GPS Window Title to : CFD3
Also, ensure that Plugin support is enabled and "Set size & Position" is disabled in Destinator configuration.
What this won't currently do
Although the launcher will only run if centrafuse is running, when centrafuse is closed it doesn't send the correct message to quit applications and freezes the app...so the closing problem still remains. This needs to be fixed in centrafuse.
Download here
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall returnThe car
Did you enable plugin support?
it was size and posish had it ticked and plugin not ticked all fine now thanks
your the man
also it doesnt freeze any more when exiting .destinator keeps running fine so its nice and easy to exit it properly once CF has closed
Great job Ninja... I am looking into the closing problem.... I will get something figured out and include in my next update..
david
Hi there,
Great job in getting it going, only one slight problem. When i went to change the the volume in centrafuse the navigation window dissapeared and alll i could see was the ninja monkey splash screen. I exited centrafuse and the window was then shown for destinator.
When you clicked volume the destinator window should have dissapeared but then reappeared after a brief moment, if it didn't then there's something wrong with your setup, it works fine here.Originally Posted by clkraj
Like I said, this is a workaround not a solution. It's just so you guys using centrafuse can at least have destinator working until we figure this thing out
Hi Ninja,
GREAT ! THANKS !
- superbowl
i never drink water cos fish ***** in it. (w.c. fields)
NM, You da Man !!!
Can't wait for "Map Monkey", although I like Gorilla Guidance myself.
Keep up the awesome work.
'94 Mazda T3500 Bus, Lilliput 7", Mouse GPS, 1GHz TC1100 Tablet PC, Inverter, HUGE Spare battery, Smart Charger, Road Runner, FreeDrive.
