I have ninja D3, and i am using it with Destinator 3 extracted Spain maps, that i moved to C:\DestinatorApps\Destinator in a folder that i named Spain.
The problem is that i can see any places (citys or streets) over the map, but this ones does not apperars on planning router lists. Why?
I can't see Poi's like airports or fuel stations over the map too.
And the router not works fine, it make one route, but not the best route.
Is possible the problem will be the map? can be older?
I try Via michelin Mapsonic too, and this one , at least, calculate correctly the route, but i like Destinator very much...
Is there any way to use mapsonic maps in destinator??
