Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Getting TomTom POI imported to D3
  1. #11
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Had very little time lately, but It'll be ready eventually
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
  2. #12
    k09
    k09 is offline
    Newbie k09's Avatar
    Feb 2005
    Budapest Hungary
    Quote Originally Posted by Matthew230
    So searching "POIHandler" gives three threads, two I started and one of them this one !!
    Can anyone else help with the original question ??
    You must to start the Destinator3 Console, choose a map, and after push the POI button.
  3. #13
    May 2005
    Derbyshire, UK
    Just to bring up an old thread for future searches....
    POIhandler now had DAT files that you just add to the favourites folder. I wish you could add to the POIs so that they are listed in order of how close you are to them...
    Old setup
    Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
    New setup
    Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
    Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
  4. #14
    FLAC mauri's Avatar
    Jan 2004
  5. #15
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    @mauri you should give step by step instructions in how this utility works.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  6. #16
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by thanatos106
    I am Italian,simply however:
    it selects to the left the type of file. DAT as example as source to be converted, and you make the search with " input file "
    it selects to the right the type of file. CSV as example as file final convert, and you make the search with " Output file "
    Click on " START " button
    If everything all ok, you have the converted file saved in the same directory of the rising file
    Mauri
  7. #17
    Variable Bitrate garo's Avatar
    Jan 2005
    Milan, Italy
    Sorry for the delay but I was REALLY busy in those days... I will finish my OV2->DAT converter during summer holidays, I will release it on my return.
    I can also implement the CVS export function but... why?
  1. Problems with D3 Embedded in Version 1.12
    By bry21317 in forum Centrafuse
    Last Post: 01-24-2005, 05:41 PM
  2. D3 POI is well $uck
    By MatrixPC in forum Map Monkey
    Last Post: 01-14-2005, 03:46 PM
  3. auto loading D3 embedded/hidden?
    By HoSS in forum FrodoPlayer
    Last Post: 12-22-2004, 06:20 AM
  4. D3 with USB GPS after HIBERNATION
    By BOND007BE in forum Map Monkey
    Last Post: 11-26-2004, 02:54 PM
  5. How do I import Speedcam's into D3 1.1
    By CdRsKuLL in forum GPS
    Last Post: 10-25-2004, 08:39 PM
