Results 1 to 3 of 3
Thread: CompassHeading D3 Winsock API call
    Jan 2005
    UK
    When I call D3Request|CompassHeading using Ninja's D3 winsock API I always get a zero value back for the heading. Can anyone tell me why?
    Thanks,
    Ric.
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Yep, that's not right
    For now you can retrieve it yourself by getting the latest RMC data (GetNMEA|RMC) and using this code
    Code:
    Private Function GetBearing(strRMC) As Double
    Dim sArray() As String
    Dim RMC_CMG       ' Course Made Good, True
    Dim RMC_MagVarNo  ' Magnetic variation
    Dim RMC_MagVarDir ' Magnetic directon
    Dim RMC_Bearing
    If InStr(1, strRMC, "$GPRMC") Then
        sArray = Split(Mid(strRMC, InStr(1, strRMC, "$GPRMC"), InStr(1, strRMC, vbCr)), ",")
        If UBound(sArray) >= 11 Then
            RMC_CMG = sArray(8)
            RMC_MagVarNo = sArray(10)
            RMC_MagVarDir = Left(sArray(11), 1)
            If RMC_MagVarDir = "E" Then
                RMC_Bearing = RMC_CMG - RMC_MagVarNo
                If RMC_Bearing < 0 Then RMC_Bearing = RMC_Bearing + 360
            ElseIf RMC_MagVarDir = "W" Then
                RMC_Bearing = RMC_CMG + RMC_MagVarNo
                If RMC_Bearing >= 360 Then RMC_Bearing = RMC_Bearing - 360
            Else
            End If
        End If
    End If
    GetBearing = Round(RMC_Bearing, 0)
    End Function
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Jan 2005
    UK
    Thanks for the info. I'll give it a go tonight.
    Ric.
  1. BASIC Stamp question
    By Banderon in forum General Hardware Discussion
    Last Post: 05-07-2004, 08:33 AM
