Results 1 to 10 of 10
Thread: Hide "SPeed"
    Jun 2004
    The North, Manchester
    Hide "SPeed"
    how do i get rid of the great big 0 MPH taking up the bottom of my gps screen??
    since it dont work want rid thanks!!
    Jun 2001
    netherlands
    it should work though, works perfect here
    time for the sig:
    '00 VW golf TDI upped to 130 HP - 18" RS 6 wheels - liliput 7" tft in indash housing - epia 10K - SB audigy - caliber 1 fahrad CAP - RF punch amp - hollywood 1.6K mono amp - boston acoustics pro - RF 10" DVD sub
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    Your GPS speed is probably more accurate than the vehicle's speedometer which are notoriously inaccurate.
    •Micke
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Yeah we were using TomTom in a '93 merc c-class and a brand new rented Passat and both speedos overread by 5mph constantly according to the GPS. Makes me wonder id speedos are made to over-read to compensate for people creepping just over the limit. Or then again it could just be under-inflated tyres.
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Quote Originally Posted by OriginalNick2
    Are you sure you're actually moving faster than 0MPH?
    ps: Search, I know I answered this not too long ago
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Constant Bitrate superbowl's Avatar
    Jan 2005
    Germany
    Quote Originally Posted by Scouse Monkey
    Hi,
    as both of your cars are german cars, he the solution:
    In germany it is illegal to use a car with a speedo displaying even 0.001 km/h less than you really drive, but it is legal that the speedo shows up to 5% higher figures.
    So the carmanufacterer design their speedos to display higher results.
    - Stefan
    i never drink water cos fish ***** in it. (w.c. fields)
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    In Aus. our desigh rules allow + or - 10% or actual speed. Unfortunately the police can book you for much less than that
    Jun 2004
    working now - cheers thread hi-jackers.
    nick
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    I thought it is illegal for the speedo to under read in most countries!
    I also heard that if your car is factory standard you can take legal action against a car manufacturer if you get pulled speeding and your speedo says you weren't. That is once the police have checked that it is in error! Hence why they over read.
    But you'd be amazed how much of an affect the tread depth has on speedo accuracy...
    Now I don't need this picking to death but just quick and rough here's why...
    Based on a tread depth of 12mm a 205/55 R16 tyre's OD can change by about an inch from new to worn, that would make a difference of 3.14" (about 80mm) per wheel revolution.
    OD = 613.9mm
    Circumference = 1984.1mm
    60mph = 96km/h
    At 96km/h wheels turn @ 806rpm = 48360rph
    so in an hour the distance you've travelled can vary by...
    48360rph x 0.080m (lets say 80mm is the amount the circumference can legally vary by)
    = 3868m/hr
    so call that +/- 4km/h (2.5mph) variation, and thats just tyre wear!!!
    There will also probably be at least a 2% tolerance in tyre diameter when they are manufactured. I'll bet that gives you the rest of the error.
    Jun 2004
    Sydney, Australia
    I actually put lower profile tyres on my mags when i got them, so i knew my speedo would be out, But i was surprised to find i was out by as much as 10% thanks to the manufacturer installed error...
    Edit, now that i think about it, it was 9.9% (incase any aussie cops see this )
  1. Hide Button Utility
    By chuckster in forum Centrafuse
    Last Post: 01-24-2005, 11:17 AM
  2. Anyway to hide cursor?
    By CHUPACABRA in forum Input Devices
    Last Post: 10-07-2004, 10:38 AM
  3. hide mouse in copilot?
    By aoLhaTer in forum Software & Software Development
    Last Post: 09-20-2004, 08:49 PM
  4. hide mouse in milkdrop
    By fantomas in forum MediaCar
    Last Post: 09-18-2004, 02:45 PM
  5. Could I hide control panel
    By Thinboy in forum Media Engine
    Last Post: 06-12-2004, 12:27 PM
