Originally Posted by
ukchris
GPSVisualizer works better with GPX files, a more standard mechanism for tracking journeys and points. It's a little trickier to create a GPX file rather than a CSV file as there are some rules you have to follow.
The best solution would be for NM to create the file in GPX format to start with or, as an alternative, write a little conversion program or script.
As an aside if you decide to try this the GPX format doesn't like more than one point per second with some tools so it is best to suppress additional points within the same second of they occur. I have done a little with this and can help out if someone wants to have a go at it.
Chris.
