Sorry if i'm covering old questions but just wondering if theres a way to convert the measurements to metric via the software?
Printable View
Have you checked all the settings?Quote:
Originally Posted by vxcarpc
It's in the settings of D3. Go menu / settings / general settings. There is a units system setting. Choose MPH or km/h :)
hi there,
i have an odd problem: when i launch map monkey the normal way everythign works. it reconnects to GPS at startup, displaying my correct position. Within Centrafuse however, the location-cursor jumps to my current location and then, half a second later, jumps to a totall different adress in my city. when i start to drive the map rotates according to my car-movement but the location is fixed to this specific adress.
I just drove to this adress and guess what happened: the location-cursor jumped irradically somewhere inside a nearby sea...
Then, when i drove back, about 100meters away from this strangly fixed location, i jumped back from the see to the mysterious location.
has anyone encountered a similar phenomenon or has a fix? As i said... normal mapmonkey works like a charm... (despite it also Starts at the mysterious adress but THEN jumps to my correct location)
If we have these gps values E023°51.232', N038°10.564' how can we convert them to such values that will be recognised by MM?:)
try
longitude is the E degrees ( 23 ) + mins 51.232/60.0 which = 23.8538666
latitude is the N degrees ( 38 ) + mins 10.564/60.0 which = 38.1760666
PS, i could be wrong, as I don't know what MM wants, but i'm assuming it's that.
Thanx a lot!!:)
I will try that tomorrow!!;)
That worked!!:)Quote:
Originally Posted by baggers
Thanx a lot!!;)
Any chance anyone knows how I can get long/lat if I click on a destinator map through MM?? I want this in order to build Speed Cam database for Greece!!:) I don't have coordinates for all the cameras, but address/#!:)
I'm glad it worked for you DjBac :D
